Home > Puma (Tdci) > Volume Control Valve - Ford part no? |
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 |
If we had a "head banging" emoticon ..... I would use it now!
22nd Feb 2017 11:12pm |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 |
Did anyone order, receive and fit a valve from diesel parts online shop? My 90 Project : http://www.defender2.net/forum/topic52774.html
28th Mar 2017 3:23pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
James
28th Mar 2017 3:30pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 |
What, this one? (been here since day 1) 1988 90 Td5 NAS soft top 2015 D90 XS SW |
tobz102 Member Since: 07 Feb 2014 Location: Atherstone Posts: 134 |
Just if anyone needed more positive reviews of replacing the vcv, I did mine yesterday and wow.
My chosen tool combination was a 5mm Allen key bit (10mm bit size) fitted into a 10mm rachet spanner with a flexi end. Literally took 15mins to take old one out and put the new one in - removing nothing else. Took it to main dealer today be recalibrated. £50 calibration, £60 part. Improvements include: Fuel consumption, off boost engine pick up, steady idle. It generally sounds much healthier through the gears. |
30th Mar 2017 6:09pm |
B4Lamb Member Since: 21 Mar 2015 Location: Abergavenny, Wales Posts: 233 |
Out of interest did it run ok after fitting the valve and before getting it calibrated (pilot learn)? I didn't get to have my new valve calibrated and I'm now out of the country for a month but I drove the defender all the way from UK to Spain via Dover towing a boat and it's working perfectly with 30 mpg average for the whole trip. Maybe I was lucky and the old cal settings match the new valve? "You are never to old to learn something new"
31st Mar 2017 10:06am |
yes I did for my 2.4 Puma. All was good. "You are never to old to learn something new" |
31st Mar 2017 10:08am |
helmutk Member Since: 12 Dec 2011 Location: Graz Posts: 15 |
Internet lore tells that the calibration irons out tolerances in manufacture (and so optimizes mpg, responsiveness, whoknowswhat...).
31st Mar 2017 10:38am |
thanks, I will give one a go I think. My 90 Project : http://www.defender2.net/forum/topic52774.html |
31st Mar 2017 11:41am |
31st Mar 2017 4:23pm |
kirk Member Since: 08 Dec 2012 Location: Abu Dhabi, UAE Posts: 28 |
After experiencing engine power issues without any engine fault codes, I found this thread (thank you!).
I ordered and I received the UK Diesel Parts VCV and now I am preparing to do the the VCV swap, but I have a question...or two. (1) Do I need to remove the current BAS remap and go back to the original factory map before I swap out VCV? (2) Is the second generation 'Bell Auto Service Remote Remap Control' (BAS2 RRC) capable of performing the VCV 're-learn' process? Once the job is complete, I will report back on the success/failure, tools, remap/relearn, and suitability of the UK Diesel Parts VCV valve. Thanks in advance for any advice you can provide. Kirk |
11th Apr 2017 9:48am |
1: Needs to happen for part 2, so yes, may as well do it before the swap.
2: Yes, it's the same two functions you did before programming the original BAS remap. One doesn't appear to do much at all, the other plays around with the engine idling and bothers your neighbors. (3: Apply BAS remap again 😆🤖) Solved the bowel problem, working on the consonants... |
11th Apr 2017 9:59am |
VCV calibration should be done on the factory map:
https://bellautoservices.co.uk/help-faq/ba...4tdci/vcv/ Edit: Outrun by agentmulder! |
11th Apr 2017 10:01am |
OK. thanks for your responses. I'll give it a go and keep you posted.
11th Apr 2017 10:47am |
