Home > Maintenance & Modifications > tdci gearbox
Caterham
tdci gearbox
Hi folks,
In about 10 weeks from now i'm looking to fit rebuilt transferbox c/w lsd, new gearbox and check the adapter shaft.
At this point I'll have a spare gearbox. I'll be looking to sell it, presumably on here is as good a place to try as any (what other applications are the gearbox used?). Should I sell it as is 60k miles or should it be rebuilt first and what cost should I expect?
Many thanks
Post #612071 25th Mar 2017 7:03pm
zsd-puma
The gearbox is also used in the Transit and Ford Mustang, although the ratios will likely be different.
or do you mean spare transfer box?
Post #612093 25th Mar 2017 7:57pm
60k is hardly run in for the main gearbox, so unless there's a known problem with it there's no point rebuilding it. It might even be worse after it's been fiddled with.
There is the small problem that it has come from your Defender, a car which is infamous throughout the world now as being the one which had an entire year's production worth of faults fitted, so the rest of the year's production could be faultless!
MT82 boxes don't seem to be vety expensive to buy. I bought a complete MT82/LT230 assembly from a breaker, about 1 year old, for about £300 not so long ago. It could cost you that to overhaul.
Post #612140 25th Mar 2017 9:47pm
Caterham
Thanks zsd. I forgot th transits aren't just front wheel drive.
Bw. Thanks for the note. Very Happy. Had hoped they might be worth a little more but hey ho. Is what it is. Thanks again.
Post #612144 25th Mar 2017 9:53pm
Caterham
Post #612147 25th Mar 2017 9:56pm
It looks as though a good second-hand MT82 now goes for £500 to £800, that sort of figure.
Post #612171 25th Mar 2017 11:17pm
Caterham
Thumbs Up
Good news BW. Where did you come across those costs - ebay?
Post #613952 2nd Apr 2017 8:22am
A quick trawl of reputable breakers on eBay.
Post #614132 2nd Apr 2017 10:25pm
Caterham
Thank you Thumbs Up
Post #614133 2nd Apr 2017 10:27pm
