Home > Technical > Front wipers have stopped
Falcon
New Zealand 2010 Defender 90 Puma 2.4 SW Indus Silver
Hi Everyone,
So my 2011 defender has had no intermittent wipers since I bought it last April. When the stalk is pushed to intermittent they just activated as if they were running at speed 1, so I thought maybe a faulty park switch or relay.
But at the weekend I was out in the rain with the wipers on speed 1 (not intermittent) and they stopped working mid wipe. They are now stuck halfway up the windscreen. The fuse has blown, and a fresh replacement pops instantly which makes sense as they are probably trying to return to their parked space at the bottom of the windscreen.
Rear works fine.
So what do you lot reckon? Faulty park switch, relay, motor, or something else, or everything?!
Thanks
Post #609276 14th Mar 2017 6:10am
rustandoil
Start with the park switch, cheap and easy.
I had similar the park switch had shorted out and blown the fuse
Post #609284 14th Mar 2017 7:26am
Also give the arms a waggle to check one or other isn't locked solid, which can happen if the rack and wheelboxes are worn. This stalls the motor and will cause the fuse to blow.
Post #609285 14th Mar 2017 7:48am
mk1collector
^^^^ this. One of the wheel boxes will be seized. Ray
My build thread
Post #609314 14th Mar 2017 10:15am
Miggit
Many years ago I had to go and Ferrari 400i which the wiper had stopped on... Having found the fuse box... which was the passenger footwell (whole thing) Shocked with hundreds of fuses... I finally found the wiper fuse and changed it...POP! Sad
I then had a look under the bonnet, would have been rude not to Wink , and discovered that one of the mounting bolts had worked loose and jammed the arm on the motor.. tightened the bolt, new fuse and away it went Mr. Green ... So the moral of the story is check everything is moving freely Thumbs Up RRC 2.4 TD... it's either a stretched 90 or shrunken 110!!
ML 270CDI
Post #609439 14th Mar 2017 7:22pm
Falcon
Thanks for the leads everyone, I'll start with that and keep you posted
Post #609536 15th Mar 2017 5:00am
Les
Ive just had the same on my 2007 Puma.
Took it to my local very good LR specialist who advised that it is the LH wiper wheelbox seizing which is a common problem.
Temp fix is to get some WD 40 in from the outside by pulling back rubber grommet on wiper and trying to let oil run in.
Les
Post #609821 16th Mar 2017 1:49pm
Falcon
Result!
So I removed the brake switch from the motor, and the plastic pin that activates the switch inside was being a bit dicky. I separated the two sides of the switch to find that the copper contact that the pin pushes to activate the switch has snapped, and bridged across two other contacts causing a short.... - hence the fuse popping instantly each time.
For now I've just put the switch back in without the broken bit shorting the switch and the wipers are working again. They don't have intermittent, or stop where they should do, but they are at least working.
A new switch should get it working 100%
Hopefully this can help someone else one day, I heard the park switches were pants but now I know why.
Post #612464 27th Mar 2017 9:50am
rustandoil
Exactly what happened to mine, in the pouring rain at night.....
Park switch is only a couple of quid Thumbs Up
Post #612472 27th Mar 2017 10:15am
