Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 40 of 81 <123 ... 394041 ... 798081>
mk1collector
Hi, I don't have any pics of mine as I didn't take any while doing it Embarassed most others as above had plates made up to put in and cut out the old panel but as I have a panel beater background decided to re shape the existing panels Thumbs Up Ray
My build thread
Post #603648 21st Feb 2017 4:39pm
Rad666
United Kingdom 1998 Defender 110 300 Tdi DCPU Keswick Green
Did you use the side supports then or have you just made the clearance in the arch
Post #603700 21st Feb 2017 7:17pm
mk1collector
I haven't used the side supports yet but do intend to when I get around to fitting them. The seats have been in for a couple of years now without the supports and I've had no problems yet but just for peace of mind I will fit them eventually. Ray
My build thread
Post #603704 21st Feb 2017 7:27pm
Rad666
Thanks for the reply, just emailed yrm see if they fancy doing some plates
Post #603722 21st Feb 2017 8:28pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Rad666 wrote:
Is it your landy? Ive already done the conversion apart from the arches, do you sell them plates?
Yes, this is my truck. The inserts are 2 pieces, then seam sealed and rivered in place.
There are a couple of awkward bends in there, used a small vice brake to do the bends. Primed, painted then installed. I added the support brackets once the seats are in. The set up is pretty solid.
 it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #603751 21st Feb 2017 9:36pm
Screbble
mk1collector wrote:
Thanks to screbble I now have a new leather steering wheel Mr. Green mine was looking decidedly tatty so I've been looking for a 36 spline (thanks to Landrover Rolling Eyes ) xs wheel for ages.
So from this
Luckily I have a steering wheel puller which makes the job easy
To this looking much smarter Mr. Green
Also fitted the rear little window security grills from mcma1
I used stainless security screws
And with the trim back in they look quite neat
And can't be seen from the outside with the tints
Thanks for looking Thumbs Up
Ray
Steering wheel looking good Ray Thumbs Up
You need to polish the centre cap/cover though Rolling with laughter
Post #608902 12th Mar 2017 4:58pm
mk1collector
Rolling with laughter the whole car needs a good de fumigating as its filthy inside and out Rolling with laughter I've got a big job to finish in the next month or two then go to town on it Thumbs Up Ray
My build thread
Post #608918 12th Mar 2017 5:46pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
H mmmmmmm, that sounds like a task for ...............
Post #608929 12th Mar 2017 6:49pm
mk1collector
Rolling with laughter dun dun dun...... Superjez!!! Rolling with laughter Ray
My build thread
Post #608944 12th Mar 2017 7:47pm
mk1collector
Finally got a few mins to put the rear door guard on, I'll keep it on until I put the new rear door on then decide if I want it on permanently or not
 Ray
My build thread
Post #613976 2nd Apr 2017 12:04pm
mk1collector
An expensive day Big Cry
Downside is it hasn't solved my problem Rolling Eyes Ray
My build thread
Post #619694 26th Apr 2017 5:25pm
grafty99
Shocked
What's the problem Ray? (Obviosly not the injectors Big Cry ) 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #619723 26th Apr 2017 7:18pm
mk1collector
Lots of black smoke Big Cry I've been told before that an injector sounds like it was dragging so we thought over fuelling from a leaking injector but apparently not. What's worse is there's a knock after replacing the injectors so I'm not sure what to do now. Ray
My build thread
Post #619806 26th Apr 2017 10:05pm
barbel jim
Oh dear Ray
Did you get any further with programming the injectors ?
If all else fails get some rigger boots, bush hat and a "NO SMOKE NO POKE" sticker Rolling with laughter Rolling with laughter
Post #619848 27th Apr 2017 7:15am
mk1collector
Rolling with laughter I was thinking more along the lines of can of petrol and a match Big Cry the nanocom may have come up trumps with some info on cylinder balance so it's going back to the garage tomorrow for one of the injectors swapping back to rule it out. Fingers crossed Crying or Very sad Ray
My build thread
Post #619873 27th Apr 2017 9:33am
