Home > Technical > Td5 Central Locking Actuator
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Evening All
I couldn't find the welcome area so thought I'd prefix my first question with an intro... This is my 1st post despite lurking for many months since acquiring my latest Land Rover - a 2002 Black LE Defender Td5 DCPU. My other LR is a 101 and I also had an SIII Lightweight until a few months ago.
The 110 is 3/4 through a complete door set replacement at the moment and along the way I'm trying to fix other things. One of which is the front passenger door locking mechanism. It works pretty well - no problems with locking via the key or the central locking. The problem is that in order to open the door from the inside you have to lift the sill button whilst pulling on the door release handle. The button tends to drop down and prevent the door opener from actuating the latch. I reckon the problem is inside the central locking actuator, which I've opened up - see photo.
The plunger is very easy to move up & down - I suspect too easily hence it not supporting the weight of the button. However - I can't see anything obviously wrong in the actuator mechanism - my guess is that there should be a friction device inside the gold banded cylinder between the grey metal gear and the plunger. Has anyone else had this problem and succeeded in repairing it?
Thanks in advance
John
Post #605439 28th Feb 2017 12:34am
mk1collector
Are you sure it just doesn't want the rod adjusting? Ray
My build thread
Post #605444 28th Feb 2017 1:15am
Intercept
That was my initial thought/hope, but after I wound the rod up to position the button correctly the actuator wouldn't lock the door.
Post #605446 28th Feb 2017 1:34am
mk1collector
I have found with a couple of mine that they get weak and slow with age so I replaced as necessary but I've not had or heard of any that work fine but drop during driving. I don't think anyone sells any of the internal parts seperately so you may struggle to fix it, but new ones aren't too expensive. Ray
My build thread
Post #605473 28th Feb 2017 10:11am
Intercept
Thanks. I'll hold fire on a new one until I've compared it to the driver's door part (which has no button droop).
Post #605478 28th Feb 2017 10:50am
Intercept
Update
The driver's door actuator was less floppy so I got a new one for the passenger door. But that didn't make any difference Sad However, the mechanism now works perfectly thanks to the zero cost modification in the photo...
So, if you have button droop, don't buy a new actuator - just add some elastic assistance Smile
Post #608569 11th Mar 2017 10:14am
dorsetsmith
So land rover tool kit in clods duck tap and elastic shot cord Thumbs Up
Post #608570 11th Mar 2017 10:19am
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Nice simple fix - and the price was right Thumbs Up
Post #608572 11th Mar 2017 10:25am
mk1collector
Looks like it's your door locking mech that's at fault then and not your actuator. Ray
My build thread
Post #608593 11th Mar 2017 12:17pm
