![]() | Home > Technical > Td5 Central Locking Actuator |
Are you sure it just doesn't want the rod adjusting? Ray
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
That was my initial thought/hope, but after I wound the rod up to position the button correctly the actuator wouldn't lock the door.
I have found with a couple of mine that they get weak and slow with age so I replaced as necessary but I've not had or heard of any that work fine but drop during driving. I don't think anyone sells any of the internal parts seperately so you may struggle to fix it, but new ones aren't too expensive. Ray
Thanks. I'll hold fire on a new one until I've compared it to the driver's door part (which has no button droop).
Update
The driver's door actuator was less floppy so I got a new one for the passenger door. But that didn't make any difference ![]() ![]() Click image to enlarge So, if you have button droop, don't buy a new actuator - just add some elastic assistance ![]() |
So land rover tool kit in clods duck tap and elastic shot cord
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
Nice simple fix - and the price was right
Looks like it's your door locking mech that's at fault then and not your actuator. Ray
