Home > Technical > Td5 Central Locking Actuator |
Are you sure it just doesn't want the rod adjusting? Ray
28th Feb 2017 12:15am |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
That was my initial thought/hope, but after I wound the rod up to position the button correctly the actuator wouldn't lock the door.
28th Feb 2017 12:34am |
I have found with a couple of mine that they get weak and slow with age so I replaced as necessary but I've not had or heard of any that work fine but drop during driving. I don't think anyone sells any of the internal parts seperately so you may struggle to fix it, but new ones aren't too expensive. Ray
28th Feb 2017 9:11am |
Thanks. I'll hold fire on a new one until I've compared it to the driver's door part (which has no button droop).
28th Feb 2017 9:50am |
Update
The driver's door actuator was less floppy so I got a new one for the passenger door. But that didn't make any difference However, the mechanism now works perfectly thanks to the zero cost modification in the photo... Click image to enlarge So, if you have button droop, don't buy a new actuator - just add some elastic assistance |
11th Mar 2017 9:14am |
So land rover tool kit in clods duck tap and elastic shot cord
11th Mar 2017 9:19am |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 |
Nice simple fix - and the price was right
11th Mar 2017 9:25am |
Looks like it's your door locking mech that's at fault then and not your actuator. Ray
11th Mar 2017 11:17am |
