Home > Maintenance & Modifications > IN NEED OF SOME HELP/ ADVICE
yorkshiredefender90
Hello all,
Having a bad week, so from the start.
Driving along I notice a clonk when taking up drive, drive around with this clonk until I get a free moment to diagnose.
Next minuet no drive at all. Driving along and its like its gone in to neutral, now I cant move at all. everything seams to be working fine, just sounds like im revving my car in neutral.
Had a look at the linkages, shafts ect cant find any. Could this be the clutch plate? I would of thought i would of know about it, if it was clutch related.
Anyone have any ideas. Im clueless.
Cheers!
Post #606102 2nd Mar 2017 6:03pm
Gearbox driveshaft output splines gone possibly. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #606107 2nd Mar 2017 6:26pm
That's assuming you have a Puma Defender of course? WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #606108 2nd Mar 2017 6:33pm
Bluest
Put it in diff lock and see if that gets you mobile. That will indicate whether the fault is before the transfer box or not. 2007 110 TDCi Station Wagon XS
Post #606110 2nd Mar 2017 6:35pm
Froglaise
If it's a Puma model, get under and have a look for some red dust around the little hole where the output shaft is. If yes, then pretty sure it's blown it's splines and you need to get one from Ashcroft.
Post #606115 2nd Mar 2017 6:49pm
yorkshiredefender90
Its a 2005 td5 unfortunately.
Ive put in diff lock, however the light is not indicating its engaged. but still nothing when in diff lock. Sad times.
I think my wallet has just run away!
Post #606116 2nd Mar 2017 6:50pm
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
If shouting at it doesnt work, and you have tried diff lock, then it would seem to be gearbox or tbox related... unless the clutch plate has exploded? does the clutch seem like its working, does the gear lever engage and disengage without using the clutch even with it in gear and the engine running? V8 90...WIP
Post #606120 2nd Mar 2017 7:06pm
mk1collector
Axle drive flanges Im betting. If the diff lock light isn't coming on the rods could be stiff/seized from little to no use. Ray
My build thread
Post #606127 2nd Mar 2017 7:33pm
yorkshiredefender90
Tried shouting, and the occasional abuse.
Im thinking its clutch plate related, I can change gear when running without pressing the clutch peddle. If it was the clutch plate would I of heard anything when it happened? As it just stopped silently. Dont know if the clonk i have when taking up drive had anything to do with this?
Post #606131 2nd Mar 2017 7:38pm
yorkshiredefender90
Cheers Ray! is there anyway I can see if it is the axel drive flanges? To be honest ive never actually used diff lock in the 5 years ive owned this 90.
Post #606132 2nd Mar 2017 7:40pm
mk1collector
Are you sure it's not just dropped out of high range? That could have been the clunk Ray
My build thread
Post #606133 2nd Mar 2017 7:41pm
mk1collector
The best way is to put it in diff lock. You could try working the lever till it eventually frees the rods, and if you have any wd40 or simillar you can spray the rods if you get under from the drivers side. Ray
My build thread
Post #606134 2nd Mar 2017 7:44pm
yorkshiredefender90
its not sadly, tried putting it in low,high an diff lock. had a clonk when taking up drive ( changing up gear) for 2 day until to this happened
Post #606135 2nd Mar 2017 7:45pm
Put it in gear with the engine running, brakes on, and look underneath (or get someone else to look underneath). If one propshaft is turning, then the fault is in the diff or axle at that end (front prop turning = front axle fault, rear prop = rear axle). In this case engaging diff lock will give you drive (the fact you're not getting the diff lock light suggests that the lock is not engaging, perhaps due to a seized linkage).
If neither propshaft is turning, you have a transfer box, gearbox, or clutch fault, or, if you're really lucky, the t-box has jumped into neutral.
Post #606145 2nd Mar 2017 8:09pm
yorkshiredefender90
Sad nothing happening underneath, so it looks like your suspicions on clutch/tbox are right. Think its going to be a garage job.
Is there anyway to see if its suck in neutral?
Post #606209 2nd Mar 2017 10:05pm
