Home > Maintenance & Modifications > Simple job
Chopperone
Simple job
Embarassed So managed to snatch a couple of hours to add some bits to my 90.
Finished off fitting the glove box kit which I had to stop because it was too dark on Friday when I was rushing to finish.
Next ; needed to do a simple job before the rugby started.
Decided to fit the locking spare wheel kit I bought last weekend from Brennan at Donington.
I have Bowler wheels so I removed the wheel nut cap & undid the locking wheel nut.
3/4hrs of an hour later I still hadn't been able to get the other two wheel nut caps off the spare wheel.
I have tried wiggling. I have tried jiggling.I have done a lot of swearing & I no further forward.
Two simple wheel cap nuts & there is absolutely no room whatsoever to get them off my Bowler wheel.
I will get them off.
However, I am very concerned that I have 4 other wheels that each have a wheel nut cap on & at the present rate of progress l am dreading having to contemplate doing this st the side of the road at night.
Anyone else had this problem?
Guy May your life be like toilet paper ; long & useful.
Post #604966 26th Feb 2017 3:55pm
Are You sure they're not just normal alloy wheel nuts?
Caps have a domed indent in the end, wheel nuts don't. Sorry if this isn't stating the obvious, but I know people who have done the same.
Post #604975 26th Feb 2017 4:50pm
Chopperone
Definitely caps.
I took the one off the locking wheel nut for a start.....
And I can wiggle them but can't get behind them to hook them out
Post #605006 26th Feb 2017 6:30pm
mk1collector
But do they have the indent like Greeni says? The normal wheel nuts are capped but the caps don't come off. Ray
My build thread
Post #605008 26th Feb 2017 6:34pm
Stacey007
Hello
Do you mean a cap that goes over the wheel nut, ie, would this type of thing help
https://www.amazon.co.uk/s/?ie=UTF8&ke...7imz2e3f_e
Post #605015 26th Feb 2017 6:48pm
Chopperone
They have indents. May your life be like toilet paper ; long & useful.
Post #605019 26th Feb 2017 6:55pm
Sulisuli
Chopperone
I changed my wheel nuts today for black ones and had 3 different types to deal with which confused me (doesnt take much) see picture below. Had 4 wheel nuts with a raised pimple??
All three types in the end got the same treatment a socket on an impact wrench Very Happy even though the caps moved prior to this I couldnt pull them off as you described so put the socket on them and spun them and off they came, if you dont have an impact wrench a socket on a long bar will take longer but will do it too. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #605020 26th Feb 2017 6:56pm
Chopperone
Because the Bowler wheels have quite a deep recess there is no room down the side of the cap to get in & then behind the cap.
I have tried drilling a hole in the cap & then trying to get a Snap On hook probe & that won't work.
I am trying not to damage my wheel so I can't do anything much more invasive at the moment but when I get the caps off l will need to look at something else instead of these poxy caps. May your life be like toilet paper ; long & useful.
Post #605028 26th Feb 2017 7:03pm
mk1collector
As said above if they have the indent then use the same wheel nut socket on a long bar and as you undo them it should break any corrosion and the cap will come off. Ray
My build thread
Post #605029 26th Feb 2017 7:04pm
Sulisuli
I was surprised how the corrosion held the caps in place and thought first of all they were ordinary wheel nuts fingers crossed the long bar and socket works to break the corrosion holding them. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #605031 26th Feb 2017 7:09pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Guy, I have to agree with the lads.The standard alloy wheel nuts also have caps on them....that aren't meant to be removed. They do, however sound loose when you get hold of them. Unlike the locking wheel nut cap, they have a convex top to them.
Stephen
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #605032 26th Feb 2017 7:12pm
Chopperone
OK chaps
For the avoidance of all doubt Smile
At the moment I am trying to get my spare off.
I recently bought a set of brand new Bowlers & tyres via my local tyre dealer.
I have removed the cap from the locking wheel nut & I can remove this wheel nut.
I have a full workshop of all sorts of tools.....
A 27mm socket does not fit. A 28mm socket spins on the cap & I cannot get it to bite.
The Bowlers have a deep recess which is higher on the rim side as opposed to the hub side.
There is NO room to get down the side of the cap.
The caps have indents in the top & they are silver in colour. They feel like caps & they certainly don't feel part of the actual
Wheel nut.
I have not tried a pneumatic impact wrench on it.
As far as I am concerned it's a cap on a nut that is held in place around it's rim .
Suitably frustrated by a seemingly simple problem!
Post #605052 26th Feb 2017 8:02pm
Photos may help.
You can have swollen nuts Laughing
Basically Defender nuts can 'swell' (from abuse) and a standard 6 sided socket would struggle to fit on and a multi sided socket will probably and can fit over
It seems you're confident they ARE covers over locking wheel nuts. So are you saying ALL the nuts are locking on your motor, or just the spare? If its ALL, it's likely there should be more 'key' sockets
Blindos suffer the same buried deep nuts Rolling Eyes I threw my locking covers in the bin and used lashings of acf on the lockers
I used a socket and spun off the covers, so I know how you can't get down the sides...
Post #605062 26th Feb 2017 8:16pm
Sulisuli
Thats odd the 27mm doesnt fit but a 28mm spins. I think if it was me Id be going back to the local tyre dealer you purchased them from to see how he takes them off because as you say imagine if you have a puncture on the roadside!! Sorry cant be of more help. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #605067 26th Feb 2017 8:21pm
mk1collector
Yes definitely swollen nuts, Rolling with laughter try knocking the smaller socket on with a nylon hammer and undoing them with a breaker bar Ray
My build thread
Post #605068 26th Feb 2017 8:22pm
