Home > Maintenance & Modifications > Simple job
Page 2 of 2 <12
Alien
Australia
Sulisuli wrote:
Chopperone
I changed my wheel nuts today for black ones and had 3 different types to deal with which confused me (doesnt take much) see picture below. Had 4 wheel nuts with a raised pimple??
All three types in the end got the same treatment a socket on an impact wrench Very Happy even though the caps moved prior to this I couldnt pull them off as you described so put the socket on them and spun them and off they came, if you dont have an impact wrench a socket on a long bar will take longer but will do it too.
A note on what I've found in the difrences of the 3 types in the photo.
(For some it's a sucking eggs moment but for others it may help)
Left is the cap for the locking nut, its got a concave dimple.
There should be a plastic removal tool in the kit with the wheel brace, jack handles and lock nut adaptor.
There is times when the adaptor strips/pins bend making it hard to use, particularly if used with a rattle gun.
We don't have the theft problems over here so I've replaced mine with standard nuts.
I'm not getting caught out 200 miles from help with a stuck locking nut.
Middle is the standard wheel nut, a clean dome finish.
Sometimes you will feel some movement, its normal and is not a cap.
Use a 27mm socket as mentioned.
Right is the spare wheel nut, it's got a convex dimple.
As with the standard nut it's not a cover even though it may have a little movement.
Use the 27mm socket to remove.
The thread in this nut allows for fitting over the longer studs on the spare wheel carrier. Cheers,
Kyle.
Post #605091 26th Feb 2017 8:59pm
Sulisuli
Thanks kyle Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #605105 26th Feb 2017 9:22pm
Chopperone
Kyle - for some reason I can't see your pics.
The next time I can have a play with this problem is Tuesday so watch this space.
Thanks for all your help so far.
Guy May your life be like toilet paper ; long & useful.
Post #605119 26th Feb 2017 9:41pm
zsd-puma
They just sound like the factory wheel nuts to me. As everyone else has said, They have a non-removable stainless finisher on them, there is usually a bit of play in the finisher, but you just stick a 27mm socket over them and undo the nut with the finisher in place.
The spare wheel nuts are different to the road wheel nuts, the locking nuts all have a concave top, the road wheel nuts are more or less flat topped, and the spare wheel nuts have a raised dome on them.
A photo of the nuts you have would help.
Post #605134 26th Feb 2017 9:58pm
Alien
Australia
Guy
I was cheating and used Suliuli's photo which is why I copied his post Wink Cheers,
Kyle.
Post #605169 27th Feb 2017 2:50am
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Maybe stating the obvious but have you tried the black cap remover that is supplied in the tool kit - the locking wheel nut adapter is normally held in it. Push/ tap it on until it clicks it on and it clipped over the wheel nut cover, pull it off and it pulls off the cover.
Darren Darren
Post #605184 27th Feb 2017 8:06am
zsd-puma
And if you do put the cap remover over a normal nut it will get stuck, but you can fit the wheel brace inside it to remove the nut, complete with cap remover. Wink
Post #605196 27th Feb 2017 8:56am
grafty99
Quote:
I have Bowler wheels so I removed the wheel nut cap & undid the locking wheel nut.
3/4hrs of an hour later I still hadn't been able to get the other two wheel nut caps off the spare wheel.
The other two nuts will be standard alloy nuts. The caps won't come off. 27mm socket can be tight but is the correct size and will fit over the finishing caps Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #605198 27th Feb 2017 9:18am
Chopperone
Severe & embarrassing apology
Embarassed Embarassed
So I revisited the problem yesterday & you chaps are right & I am wrong Bow down Bow down Bow down
My nuts are now loose.
Still need to find something way more user friendly & black for my Bowlers.
Thanks for everyones input
Post #605675 1st Mar 2017 7:32am
zsd-puma
There are black versions of the standard nuts available.
http://www.ebay.co.uk/itm/Set-of-20-X-27mm...3641.l6368
I've no experience of how well the black finish lasts mind you.
Post #605717 1st Mar 2017 10:54am
Alien
Australia
Post #605729 1st Mar 2017 11:43am
zsd-puma
Those ones from Mudstuff only fit M6, M8 and M10 nuts, so they're somewhat small for 27mm wheel nuts.
Post #605735 1st Mar 2017 12:10pm
Sulisuli
I have just fitted the ones from LRI last weekend, they are painted not anodised so need to be mindful, i removed old silver ones with with impact wrench but fitted black ones with socket and long bar then torque wrench and no paint damage. If you want black anodised then I found a company but they will cost nearly 300 including locking nuts
 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #605848 1st Mar 2017 8:08pm
Thumbs Up glad you got it sussed.
Post #605868 1st Mar 2017 8:43pm
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
Alien wrote:
Sulisuli wrote:
Chopperone
Found this today and checked my wheel nuts. Found 2 of the raised dimple spare wheel nuts on the wheels and swapped them with the smooth head nuts that were incorrectly on the spare wheel.
As a bonus the annoying rattle when closing the back door has now been solved. Thumbs Up Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #967035 7th Oct 2022 6:31pm
Page 2 of 2 <12
