Home > Maintenance & Modifications > How to run video cable from reversing cam to cabin (DEF130)?
RoadForce
Netherlands 2000 Defender 130 Td5 HCPU Coniston Green
Hi,
I am about to install my reversing camera and was wondering what would be the best way to run the video cable from let's say the rear cross member to the cab on a 130 HCPU?
Where to run it, how to attach it, etc?
I already worked out that I will probably use the hole for the handbrake cable to get the cable into the cab, but how do I best run the cable from the rear and make sure it stays put? Defender 130 HCPU Td5 MY2000
Post #604515 24th Feb 2017 2:09pm
zsd-puma
For my 110, i strapped the cable to the trailer harness as far as the seat box under the car, then strapped it to the harness from the seatbox up into the engne bay before poking it through the rubber grommet in the bulkhead behind the dash.
Have a look on Topix for the cable routing for the 13 pin trailer harness that gets you as far as the seat box.
Post #604519 24th Feb 2017 2:18pm
mk1collector
Cable tie it to the fuel lines that run down the top of the chassis leg, then up the bulkhead and in through the rubber grommet at the back of the dash. Ray
My build thread
Post #604536 24th Feb 2017 3:56pm
mick
As above Thumbs Up I've run a few cables on mine same way but I put the cables in some trunking as well Thumbs Up
Post #604561 24th Feb 2017 5:34pm
RoadForce
Yes I had thought of ziptie-ing the cable to the fuel lines, but dismissed the idea for fear of abrasion of the fuel lines. It doesn't hurt then? Defender 130 HCPU Td5 MY2000
Post #604585 24th Feb 2017 6:40pm
zsd-puma
If it's adequately tied on then it shouldn't move enough to abrade.
Post #604588 24th Feb 2017 6:45pm
RoadForce
Won't the tiewraps cut into the fuel lines? Defender 130 HCPU Td5 MY2000
Post #604600 24th Feb 2017 7:17pm
zsd-puma
no more than the plastic clips that hold the fuel line as standard.
Post #604653 24th Feb 2017 10:41pm
RoadForce
Ok that settles it then, thanks! Defender 130 HCPU Td5 MY2000
Post #604729 25th Feb 2017 12:57pm
