![]() | Home > Puma (Tdci) > Volume Control Valve - Ford part no? |
B4Lamb Member Since: 21 Mar 2015 Location: Abergavenny, Wales Posts: 233 ![]() ![]() ![]() |
Regarding the hex key size to use.
I replaced my VCV today as it's warmed up outside and I could feel my fingers. It's definitely a 5 mm Allan key that fits perfectly. Are you sure you are trying to remove the VCV? It's a right fiddle getting in there and I used a combination of tools. I ended up cutting off a 30 mm length of an Alan key and put that in 5 mm socket with a 1/4" drive then a 1/4" to 3/8" drive converter a 3" x 3/8" drive extension a universal drive joint a 6" extension and finally a 3/8" drive ratchet wrench. I had to reverse the 3" extension and universal joint position for the bolt nearest to the engine block. I used masking tape to keep the 5 mm key in the 5 mm x 1/4" socket to stop it falling out, worked a treat. I've got big size 12 hands and it was a right sod of a job but did it without removing a thing else in about 1 hour. Most of the 1 hour was working out what tool arrangement would work. Ill post some pictures of the tool arrangement. The good news is its fixed the eratic revs issue so well worth the sore hands. It seems like it's running well without having the relearning procedure but ill get this done next. "You are never to old to learn something new" |
topq1967, you went from saying a 5 mm hex key not fitting to relearning the pump with a diagnostic tool, so what happened with the tools? By the way the VCV is a proportional flow valve it is not a sensor. "You are never to old to learn something new" Last edited by B4Lamb on 13th Feb 2017 10:31pm. Edited 1 time in total |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
I'll add to the literature...
My tool of choice (ahem, necessity) was this combo: ![]() Click image to enlarge The UJ moved up and downstream depending on which bolt I was working on and if I was lefty loosening or righty tightening. The job of holding the unit in place while the gasket and bolts were inserted and so on was made easier by 'removing' one of the lines to the vacuum pump. I did this by mistake, had a 'oh sh it!' moment, but then nothing came pouring out, and it went back in nicely, so I pulled it out again. Wee bit more space for the left hand to get in there ![]() Anyone know the correct torque for the bolts? ![]() |
Great minds must think alike agentmulder. The picture show the two tool arrangements I used. Despite the lack od space to work I just kept calm and persevered. As you stated the UJ was essential in this tooling set up.
![]() Click image to enlarge ![]() Click image to enlarge "You are never to old to learn something new" |
helmutk Member Since: 12 Dec 2011 Location: Graz Posts: 15 ![]() ![]() ![]() |
I just replaced my VCV (literally). Because of your Pics of the recommended assembly of tools it was not as much of a hassle as it might have been, so thanks for that!
![]() Someone here wrote that the VCV "is a pig to get to". If I was a pig , I would strongly protest this defamation! There must be a special place in hell for some engineers - my dad concurred (being one himself!). ![]() Otherwise a straightforward operation, did the learning with the RRC, applied remap, runs like a charm again! |
Well done Helmutk, I'm glad the info was of some use. I assume you didn't need to change the common rail pressure sensor? How many km did the old VCV last out if interest and we're the symptoms the classic set as described elsewhere on this forum?
Cheers, John. "You are never to old to learn something new" |
Hi John, no need to change the pressure sensor (relieve valve?) obviously, as all symptoms are gone.
In order of appearance I had: erratic idle, high fuel consumption, lack of power, motor stutters and stops sometimes when in idle. When I did the remap almost exactly one year ago at 80k km, Steve Bell suspected the VCV when the pump learning procedure failed repeatedly. (However, I guess this might rather have been due to low coolant temperature. Just reaching 80�C is not enough) I bought the spare then, but never got around to do the swap. ![]() Great forum, as a silent reader (mostly) I got huge info and advice while buying the Defender and afterwards! ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17691 ![]() ![]() ![]() |
The pressure sensor seems to be quite robust and reliable, I haven't had to change one yet. The relief valve is also fairly reliab;e but can get "popped" if you have a faulty VCV. Again I haven't had to chage one yet.
There is certainly no reason to assume that if the VCV is faulty the others must of necessity be changed at the same time. |
That's exactly my sentiments Blackwolf. The pressure sensor is electronic with no moving parts so if it was going to fail it would be completely random and not related to mileage. As you pointed out previously, if you were selling them you would advise changing the sensor with the VCV haha
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 ![]() ![]() ![]() |
I see Diesel Parts Direct are selling them on offer for �54.17 - manufactured by Denso. That is if you use the Ford part number....is that number (6C1Q-9358-AB) correct for both Puma 2.4 and 2.2?
So yet again the exact same symtoms. My VCV started to play up a month ago and got steadily worse each day after that. The mileage now is just coming up to 80k miles so a bit more than yours but in the ball park. Did you read my dit that I submitted last night on the operation of the valve and the suspected failure mechanism? Its on another thread under Puma called Erratic Idle or something like that. Cheers, John "You are never to old to learn something new" |
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 236 ![]() ![]() ![]() |
Are we talking about the same valve?
![]() Click image to enlarge If this is the VCV.. And this is the place it belongs at the back of the pump on the Lefthandside of the engine before te inletmanifold ![]() Click image to enlarge The downpipe from the inlet manifold blocks to get at the rear of the hex bolts properly. I tried to get at them via the rear of the inlet with a longer bar. But that is not possible to. ![]() Click image to enlarge this is a slightly wider view. ![]() Click image to enlarge The hex socket is to long. Last edited by TopQ1967 on 15th Feb 2017 11:41am. Edited 1 time in total |
![]() Click image to enlarge There is only about 30 mm behind the bolt. ![]() Click image to enlarge Tools available. So you are working on another engine setup (2,4 perhaps) or I miss the point completely! |
Yes that is the VCV. My tooling arrangement worked for the 2.4 TDCI Puma Defender. The 2.2 may have more stuff in the way. I'm sure the two securing screws are the same M6 size that need an 5 mm hex key. "You are never to old to learn something new"
