Home > Td5 > Td5 not starting and smoking
Landyash
England 2007 Defender 110 Puma 2.4 DCPU Stornoway Grey
Hi all my defender td5 was ticking over today when all of a sudden it started to misfire then cut out it was quiet low on fuel, so I put £20 in a Jerry can but would still not start.
After cranking over for ages it started but was smoking really bad,I have not driven this in a while only up and down the road.
Can any body point me in the direction of sorting it out?
So far I have recently change oil filters oil including diesel fuel filter and genuin Maf sensor.
The only thing I have noticed when you first start it up it want Rev for about 10 seconds but then it's fine.
Cheers Ash
Post #601262 12th Feb 2017 6:50pm
mk1collector
Have you tried the fuel purge? If not try pumping the accelerator 7 or 8 times until the mil light starts flashing then let the purge run until it finishes and try starting the defender again. Ray
My build thread
Post #601268 12th Feb 2017 7:05pm
Landyash
Hi Ray,
thanks for the quick reply yes I have tried that.
Thumbs Up
Post #601270 12th Feb 2017 7:09pm
Cactus79
Answer the following
Oil level high?
Oil smell of diesel
Fuel pump noisy?
Oil in Red ECU plug?
Diesel down the back right of engine?
Make of fuel filter?
Post #601274 12th Feb 2017 7:20pm
Landyash
Hi cacuts79 thank for the reply here are my answers below.
Oil level high? Normal
Oil smell of diesel No
Fuel pump noisy? A little
Oil in Red ECU plug? No
Diesel down the back right of engine? No Looks like a new fuel regulater fitted.
Make of fuel filter? MAHLE
Got it to run breifley but it's smoking and running like a bag of s*it also sounds it's misfiring and loads of smoke.
Cheers Ash
Post #601282 12th Feb 2017 7:29pm
Cactus79
If the smoke burns your eyes then it's unburnt diesel which means probably air in system, blockage on the return or dead injector given no fuel in oil.
You can either pull injector plug of each injector in turn or put on diagnostics to confirm.
Post #601289 12th Feb 2017 7:40pm
Landyash
Thanks for the reply cacuts79 I have had my nano com plugged in and it shows not faults but I must admit I am a complete novice with it Laughing
I have took a picture of the injector readings below
Could it be the injector seals?
Cheers Ash
Post #601296 12th Feb 2017 7:49pm
Cactus79
Is that at Idle?
Post #601298 12th Feb 2017 7:57pm
Landyash
No when cranking it wouldn't start then.
Post #601299 12th Feb 2017 8:00pm
Cactus79
If its not starting you are into a bigger issue with either multiple cylinders or fuel pressure problems.
Can you get a video with fuel pump noise?
Post #601319 12th Feb 2017 8:20pm
Landyash
Cacuts79 I will try to get a video uploaded tomorrow. Thumbs Up
Thanks again Ash
Post #601331 12th Feb 2017 8:39pm
mk1collector
If the fuel pump sounds noisey I'd go for injector seals and washers which can make it really hard to start in my experience Ray
My build thread
Post #601362 12th Feb 2017 10:25pm
miker
Cylinder imbalance values only really valid when it's settled at idle. While cranking I'd expect them to be all over the shop.
Post #601375 13th Feb 2017 12:30am
Landyash
Here is a video of the fuel pump and starting issue.
I placed the phone on the drivers side rear wheel so it nearer to the fuel pump.
thanks Ash
Post #601417 13th Feb 2017 9:44am
isacs
Pump sounds ok to me
Post #601420 13th Feb 2017 10:00am
