Home > Td5 > Td5 not starting and smoking |
lozza Member Since: 13 Oct 2016 Location: oxfordshire Posts: 190 |
injector seals,just had the same problem...no indications anything wrong beforehand loz |
13th Feb 2017 5:50pm |
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 286 |
Thanks for the reply guys.
Lozza I bought a genuine injector seals kit ages ago and think I try them just in case, is there any easy way of removing them or should I just buy the removal tool? Cheers Ash |
13th Feb 2017 6:40pm |
Cactus79 Member Since: 09 Jan 2017 Location: Cheshire Posts: 51 |
Long 5mm allen key like
Make sure the bottom of the hole is near spotless and inspect around the holes for cracks at the same time. Also, extract any excess diesel from the top of the piston, you'll need a syringe and small tubing. In comparison to my fuel pump, yours is a little louder though doesn't sound as if there's much air in there. |
13th Feb 2017 6:51pm |
Thanks carcuts79
13th Feb 2017 7:06pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1630 |
bottom of the fuel pump covered in crap?
20th Feb 2017 12:17am |
