![]() | Home > Wheels & Tyres > fitting 265/75/16 |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Straight swap mine are fine
robtd590 Member Since: 27 Dec 2016 Location: Somerset Posts: 26 ![]() ![]() ![]() |
Cheers mick,
No spacers? Did you need to adjust your steering stop bumps? |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
All other things equal there will be +0.3% slower reading on your speedo with the BFGs
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
You may need to adjust the steering stops depending on whether they have been adjusted already to get maximum lock from the 235s.
If they're still on the factory settings then it's likely that they'll be ok ![]() Either way it's an easy job to do ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Cheers for your help chaps
Not bothered with my stops there's only a slight rub on full lock
Bathale Member Since: 02 Sep 2016 Location: South West Posts: 100 ![]() ![]() ![]() |
265-75-16 BF Goodrich AT's on mine as standard, fitted 30mm spacers and wound in the steering stops, it now has a good tight turning circle and disappears up it own exhaust pipe quicker than that........
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 ![]() ![]() |
Unbelieveable....
I passed by looking for clues as to whether my 265 would be ok if I removed my wheel spacers and right by the top I find this! Prompted by the wish not to have constant mud spray up the side, I may give it a go...I can always put them back. Thanks. ![]() |
