Home > Wheels & Tyres > fitting 265/75/16 |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Straight swap mine are fine
11th Feb 2017 11:03pm |
robtd590 Member Since: 27 Dec 2016 Location: Somerset Posts: 26 |
Cheers mick,
No spacers? Did you need to adjust your steering stop bumps? |
11th Feb 2017 11:24pm |
All other things equal there will be +0.3% slower reading on your speedo with the BFGs Solved the bowel problem, working on the consonants...
12th Feb 2017 4:32am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4786 |
You may need to adjust the steering stops depending on whether they have been adjusted already to get maximum lock from the 235s.
If they're still on the factory settings then it's likely that they'll be ok Either way it's an easy job to do 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
12th Feb 2017 8:14am |
Cheers for your help chaps
12th Feb 2017 9:19am |
Not bothered with my stops there's only a slight rub on full lock
12th Feb 2017 9:52am |
Bathale Member Since: 02 Sep 2016 Location: South West Posts: 100 |
265-75-16 BF Goodrich AT's on mine as standard, fitted 30mm spacers and wound in the steering stops, it now has a good tight turning circle and disappears up it own exhaust pipe quicker than that........
1st Mar 2017 7:35pm |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 |
Unbelieveable....
I passed by looking for clues as to whether my 265 would be ok if I removed my wheel spacers and right by the top I find this! Prompted by the wish not to have constant mud spray up the side, I may give it a go...I can always put them back. Thanks. |
7th Mar 2017 8:21pm |
