![]() | Home > Maintenance & Modifications > bowler transfer lever |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
didn't get any instructions.... how long do i cut it?
anyone know of online instructions... cars half apart ![]() |
nope
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Not brilliant considering how much they are
![]() Self confessed mileage hunter ![]() |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
I never thought they would be at all comfortable either!
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Very happy with mine,, nice positive feel to the stick now
But sorry, i bought mine already modified, and were a direct replacement ![]() ![]() Click image to enlarge California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
there fitted...
another busy day... the new sub is a little bit ridiculous, hopefully all finished tomorrow, hannibal rack and lazer on saturday morning then off to twisted for all my new leather bits next week |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
And the answer is....
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Photos, photos, photos
![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
didn't take one of how i cut it but fairly easy to explain with the following...
i sliced the existing transfer stick off, theres a nylon white bit left on the steel bar, you don't need a angle grinder like stated just a good quality blade... Been busy as installed a slick shift at the same time and it rattles like you wouldn't believe, shifts beautifully but that rattle... Will re install my SVX gearstick and see if its the weights... otherwise hopefully this ghetto tape fix for the slick shift works otherwise I'm not a happy bunny having just stuck down a brand new premium carpet set ill have to tear up ![]() ![]() Click image to enlarge This is the required length to cut it, i eye balled it and got it mm perfect... ![]() Click image to enlarge |
racy31 Member Since: 23 Oct 2013 Location: Notts Posts: 4 ![]() ![]() ![]() |
![]() Click image to enlarge TJ, your lever looks to be fitted 180 degrees out to the ones in the stock pics |
'Been busy as installed a slick shift at the same time and it rattles like you wouldn't believe, shifts beautifully but that rattle...
Will re install my SVX gearstick and see if its the weights... otherwise hopefully this ghetto tape fix for the slick shift works otherwise I'm not a happy bunny' Did you get the rattle on the Bowler stick as well? Ive got the rattle on the standard lever (and it isn't the weights). Was hoping a different lever would solve it. |
Correct, Well spotted
Works for me, when fitted the other way round, Cubby lid opens, Levers fall to hand better from cubby lid California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Rattle on all 3 gear sticks, bowler being worse... I've taped it and done the weights now which is better but still get a rattle I was also at probably the most 'premium' defender modifiers yesterday who also said they've had a fair few issues with them... |
![]() No rattles on mine ?? but still under 6,000 miles California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
