![]() | Home > Maintenance & Modifications > Puma dash CANbus controller |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
Nothing to do with me, but over on the D90 site, a chap has finally made an adaptor to run the puma dash.
http://www.defendersource.com/forum/f19/pu...79681.html |
Am I reading that correctly?
Does this allow you to put the Puma dash into a pre-Puma vehicle? |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2698 ![]() ![]() |
That's a good step forward. And plans for V8 & Tdi too, excellent.
It will allow the use of a Puma dash in a pre-Puma vehicle, at the moment only with the LS engine/ECU setup but once they sort it for V8/Tdi you'll be able to link it to any engine. Td5 doesn't use CANBUS so those gauges can be made to work with practically any engine/vehicle quite easily. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3655 ![]() ![]() ![]() |
wont this just make the market for stealing pumas even greater another bit you can retro fit to an older model DEFENDER 90 TDCI XS,
Clement Member Since: 16 Jan 2017 Location: Beirut Posts: 1 ![]() ![]() ![]() |
Hi guys
Do you have any news about that CAN converter that will allow a PUMA dash to read a rover V8? Many thanks |
stobbie Member Since: 04 Dec 2015 Location: zenderen Posts: 17 ![]() ![]() ![]() |
I've been in touch with safari HP because I would like to order one. We are going to build a TD5 with puma dash in a few months.
They want me to take some measurements, voltage on RPM gauge at three points and voltage on temp gauge at three points. I think I won't take the voltage of the RPM output of the TD5 Ecu but that I will add a 'W' connection to the alternator, that way it will work on a 300TDI as well. But haven't had time to take measurements yet. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
Aaaargh if only I had the time to finish my controller
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
Are you making one from scratch Martin? 2002 90 Td5 Station Wagon
Yes, from scratch. I've had a prototype system running a Puma dashboard and set up to read Td5 inputs. Just haven't had the time to get it developed any further
![]() ![]() Maybe I should crowdfund getting it finished? ![]() ![]() ![]() |
Very nice
![]() Crowd funding can be very successful, there are a lot of startups who have gained substantial funding to get products to market. Can't harm to give it a go ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Have you deciphered all canbus messages already?
Than it would not be too difficlut to built with an arduino? I haven't heard back from safari HP . They said they would build one for me, but after that they haven't responded to any of my emails anymore. I think it would be best not to have the TD5 ecu send the temp, but to use a universal VDO sender, then it could be used on all engine types. If anyone on here can build an interface I'm happy to buy one. A few years ago I wanted to build one my self with an arduino with canbus shield but I have the same problem... no time.. |
Yes, dash is fully operational on the bench and reads Td5 type signals
Lstheida Member Since: 29 Oct 2017 Location: Drachten Posts: 8 ![]() ![]() ![]() |
Hello,
Martin did you make any Progress with the controller? maybe alradey start a crowdfund? also ibeen in contact with safari HP but stil they say it would take 3 months. I would be realy interested in a controller or at least in the code to control the defender dash. recently started to rebuild my td5 auto. bougt a complete donor due to the time availeble and aranged some help. I would like to ude the td5 instruments. i like the look. but don't have the time to find out the complete logic. I willing to pay for the code or a controller. . maybe you can send me a PM? Lennard, |
Yes I've made some progress, reply with another message here and then we can exchange PMs (you need 3 posts to send PMs)
