Home > Maintenance & Modifications > Puma dash CANbus controller
Page 1 of 4 1234>
Nothing to do with me, but over on the D90 site, a chap has finally made an adaptor to run the puma dash.
http://www.defendersource.com/forum/f19/pu...79681.html
Post #583531 8th Dec 2016 6:32pm
Am I reading that correctly?
Does this allow you to put the Puma dash into a pre-Puma vehicle?
Post #583827 10th Dec 2016 9:46am
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
No, It allows you to fit a GenV1 / LS v8 into a Puma Defender and link the GM loom to the puma dash and have the instruments work without needing to (amongst other things) keep the puma engine Ecu.
Its a massive step forward. They are also looking at doing the same for the TD5 Dash but its too late for me! 2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #583841 10th Dec 2016 11:09am
Retroanaconda
That's a good step forward. And plans for V8 & Tdi too, excellent.
It will allow the use of a Puma dash in a pre-Puma vehicle, at the moment only with the LS engine/ECU setup but once they sort it for V8/Tdi you'll be able to link it to any engine.
Td5 doesn't use CANBUS so those gauges can be made to work with practically any engine/vehicle quite easily.
Post #583881 10th Dec 2016 4:10pm
LR90XS2011
wont this just make the market for stealing pumas even greater another bit you can retro fit to an older model DEFENDER 90 TDCI XS,
Post #583887 10th Dec 2016 4:59pm
Clement
Lebanon 1990 Defender 110 V8 Petrol SW Auto Stornoway Grey
Hi guys
Do you have any news about that CAN converter that will allow a PUMA dash to read a rover V8?
Many thanks
Post #593468 16th Jan 2017 10:01am
stobbie
Netherlands 2009 Defender 130 Puma 2.4 HCPU Fuji White
I've been in touch with safari HP because I would like to order one. We are going to build a TD5 with puma dash in a few months.
They want me to take some measurements, voltage on RPM gauge at three points and voltage on temp gauge at three points.
I think I won't take the voltage of the RPM output of the TD5 Ecu but that I will add a 'W' connection to the alternator, that way it will work on a 300TDI as well.
But haven't had time to take measurements yet.
Post #599692 6th Feb 2017 8:29pm
Martin
Site Admin
Aaaargh if only I had the time to finish my controller Big Cry  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #599706 6th Feb 2017 9:06pm
grafty99
Are you making one from scratch Martin? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #599714 6th Feb 2017 9:18pm
Martin
Site Admin
Yes, from scratch. I've had a prototype system running a Puma dashboard and set up to read Td5 inputs. Just haven't had the time to get it developed any further Sad Sad
Maybe I should crowdfund getting it finished? Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #599720 6th Feb 2017 9:30pm
grafty99
Very nice Thumbs Up
Crowd funding can be very successful, there are a lot of startups who have gained substantial funding to get products to market. Can't harm to give it a go Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #599727 6th Feb 2017 9:40pm
stobbie
Have you deciphered all canbus messages already?
Than it would not be too difficlut to built with an arduino?
I haven't heard back from safari HP . They said they would build one for me, but after that they haven't responded to any of my emails anymore.
I think it would be best not to have the TD5 ecu send the temp, but to use a universal VDO sender, then it could be used on all engine types.
If anyone on here can build an interface I'm happy to buy one. A few years ago I wanted to build one my self with an arduino with canbus shield but I have the same problem... no time..
Post #605104 26th Feb 2017 9:20pm
Martin
Site Admin
Yes, dash is fully operational on the bench and reads Td5 type signals  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #607264 6th Mar 2017 4:58pm
Lstheida
Netherlands 2005 Defender 110 Td5 XS CSW Auto Bonatti Grey
Hello,
Martin did you make any Progress with the controller?
maybe alradey start a crowdfund? also ibeen in contact with safari HP but stil they say it would take 3 months.
I would be realy interested in a controller or at least in the code to control the defender dash.
recently started to rebuild my td5 auto. bougt a complete donor due to the time availeble and aranged some help.
I would like to ude the td5 instruments. i like the look. but don't have the time to find out the complete logic.
I willing to pay for the code or a controller. . maybe you can send me a PM?
Lennard,
Post #660266 29th Oct 2017 1:14pm
Martin
Site Admin
Yes I've made some progress, reply with another message here and then we can exchange PMs (you need 3 posts to send PMs) Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #660524 30th Oct 2017 10:39am
Page 1 of 4 1234>
