![]() | Home > Maintenance & Modifications > Alive Tuning's ATRIC Remap. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
Its all about faults.
The returns are faults logged (just like every pc) but like you say it's about when it's a problem. I would rather see all of them, than have them prescreened as actually you can star to see more faults. Mike |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
The ability too see all faults is great Mike, its then having the ability to split them into tested and non tested DTC's which in my view would make the case for a dealer repair. After all if you know its logged as a tested DTC then you know it will show up on IDS meaning the fault would be repaired under warranty. The confusion is coming from having lots of DTC's and not knowing if they are tested or not? As I said you can monitor what comes and goes and after a while you will get to know which ones are showing all the time and therefore a problem to be addressed, where as others come and go and are less worrisome.
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
do you really think you will be able to tell the difference ?
i doubt it very much i think the tuning will be pretty much the same ? imho steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Thought I would try and explain the differences in DTC codes. So here goes:
There are basically two types of DTC codes for OBDII Diagnostics: Emissions related DTC's Tested DTC's Type A 1. Emissions related. 2. The Malfunction Indicator Lamp (MIL) will be illuminated as soon as the error occurs. 3. Stores a freeze frame DTC after one failed driving cycle.( history DTC is stored ) Type B 1. Emissions related. 2. Sets a Pending Trouble Code after one failed driving cycle. 3. Clears a Pending Trouble Code after one successful driving cycle. 4. Turns on the MIL after two/three consecutive failed driving cycles. 5. Stores a Pending Trouble Code as a DTC after two consecutive failed driving cycles. Conditions for Clearing the MIL/DTC – Type A or Type B The MIL will turn off after four consecutive driving cycles in which the diagnostic runs without a fault. A history DTC will clear after 40 consecutive warm up cycles without a fault. DTC(s) can be cleared by using a scan/diagnostic tool. Non–Emissions Related DTCs Un Tested DTC's Action Taken When the DTC Sets 1. The Malfunction Indicator Lamp (MIL) will not illuminate. 2. The ECM will record a DTC at the time the diagnostic fails. Conditions for Clearing the DTC A history DTC will clear after 40 consecutive warm up cycles without a fault. DTC(s) can be cleared by using a scan/diagnostic tool. How to read a DTC Code The DTC value will help you narrow down the specific component or module in question. A DTC has a standardized format that can be interpreted as follows: The first part of the DTC is the Alpha Designator. The alpha designator will be: B - Body electronics (i.e., door and hood latches) C - Chassis (i.e., traction control or ABS) P - Powertrain (i.e., engine, transmission) U - Network communications for the different control modules Second Digit - Code Type The second digit identifies whether the code is a generic code (same on all OBD-II equpped vehicles), or a manufacturer specific code. 0 = Generic (The diagnostic codes that are required by law on all OBD II systems are "generic" in the sense that all vehicle manufacturers use the same common code list and the same 16-pin diagnostic connector. Thus, a P0301 misfire code on a Ford means the same thing on a Vauxhall, Citroen, Toyota or Mercedes.) 1 = Enhanced ( Each vehicle manufacturers also have the freedom to add their own "enhanced" codes to provide even more detailed information about various faults. Enhanced codes also cover non-emission related failures that occur outside the engine control system. These include ABS codes, HVAC codes, airbag codes and other body and electrical codes.) Third Digit - Sub-System The third digit denotes the type of sub-system that pertains to the code 1 = Emission Management (Fuel or Air) 2 = Injector Circuit (Fuel or Air) 3 = Ignition or Misfire 4 = Emission Control 5 = Vehicle Speed & Idle Control 6 = Computer & Output Circuit 7 = Transmission 8 = Transmission 9 = SAE Reserved 0 = SAE Reserved Fourth and Fifth Digits These digits, along with the others, are variable, and relate to a particular problem code error number So let's diagnose a DTC, I've picked P0404-73 EGR control circuit range/performance: actuator stuck closed so we have: P = Powertrain (engine, transmission) 0 = Generic 4 = Emissions control 0 4 =This is the specific error code within Emission control. In this case the EGR control circuit range/performance -73= This is a specific problem, in this case the actuator is stuck closed. 74 means its stuck open. Hope this helps somebody, somewhere ![]() ![]() |
Very helpful Bri
Augusto Member Since: 01 Feb 2011 Location: Munich Posts: 35 ![]() ![]() ![]() |
To Gary or BAS:
In order to be more precise when ordering a remap, what kind of inputs you need from me to do your job ? What questions will you ask me? What parameters I should start to considering? Just to think about it. Thanks |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Hi i would need really to know very simlar to this PDF of the puma maf developement im starting in the next few days. http://www.defender2.co.uk/gallery/albums/...rm%202.pdf We will be starting this project in the next day or so to locate and iisloate puma drivbility faults from failing components and vehicle modification clashes on tuned cars like Decat exhausts etc etc. As with all of our BAS tuning on every model we dont just produce something and leave it be, we are always working to improve perfect and help our customers with issues they may or may not have even if its an original underline car issue or from a modification made that was not present as the time of original tune. We are probabally one of the very few tuning companys that keep spending money on developement of products as landrover make changes to their base software. Pete Last edited by bell-auto-services on 16th Feb 2011 12:50am. Edited 1 time in total |
An informative post Lorryman100, you have been going some homework
![]() To clarify and add to it since im in the know ![]() Puma error dtc age limit is 255 Counts of key cycles before dtc is auto removed Puma error with mill lamp on dtc age limit is 40 Counts of warm-ups before dtc is auto removed These options are also setable and adjustable or even removable via tuning if you know where to look and what to change, every single fault type in the car is available for modification if needed. In fact i may change the shown NON tested dtcs and their age limit before clearing in my tuning to help the user determine the real faults if any. Funny really as ive seen landrovers updates many, many times change the (DTC filter mask) for various faults and socalled fixes they come out with. Battery monitoring was one that springs to mind on the Discovery 4 Pete |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
He's not making this up you know! ![]() ![]() |
Now for the stupid question ![]() |
Yes this is normally the case.
heres another 255 count: 10AS ECU plip code = 255 rolling code count |
Alive Tuning's ATRIC Remap.... Arriving in the morning
Good one Karl
