![]() | Home > Maintenance & Modifications > Alive Tuning's ATRIC Remap. |
You just take off the remap file and replace it with the original engine fuel file using the Atric remap interface, takes about 10mins from start to finish
TheTechnobear Member Since: 28 Jan 2011 Location: Guadix, Spain Posts: 54 ![]() ![]() ![]() |
Such good reviews, looks like a very interesting upgrade
![]() I spend much of my time on country roads, and mud tracks, Im assuming the improved 'smoothness' should help there too.. Any experiences? Any thoughts on how a remap might be tailored for this? |
Did mine today and tried it out on the way to work. Huge difference
![]() Gary at Alive is very helpful and after a week or so I will call him again to see if the file needs adjustment. He warned me of torque judder in the front prop, so I will be looking out for that especially. One strange thing though - no more EGR "chucka x 5" (self cleaning?) when switching off... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Augusto Member Since: 01 Feb 2011 Location: Munich Posts: 35 ![]() ![]() ![]() |
How about anti stall feature? Still working with new mapping?
Thanks, Augusto. |
Anti-stall is working fine + now with a bit more torque, I can pull away in second gear more gently than before (normally a bit tricky in a 110). Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
The map comes with the EGR disabled - similar to the Td5 EGR blanking, but done with software rather than hardware. It means you are getting cold clean air into the inlet all the time for a more efficient and powerful burn. |
Thanks - know if there are any longer-term side effects? Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Ranger Member Since: 17 Nov 2011 Location: United Kingdom Posts: 75 ![]() ![]() ![]() |
Had the Stage 1 package done on my 110 TD5 CSW last month. It was carried out by Beyond Performance 4x4 in Belfast. The remap part of the package is by Alive Tuning. Together with the EGR blanking kit and decat downpipe, it's like driving a different veh. The power is smooth through the range, no flat spots and the exhaust note is brilliant. It had a remap already done by Simmonites when I bought it and it used to smoke like a steam train, no smoke now, well impressed.
Not sure, Matt. I think EGR's are yet another way of creating more issues - I can't see how they will save the planet when so many vehicles are running around with semi-issues, and as a result are polluting more. It works against itself. I want to talk to Gary about it at some point. It would be nice if they ran a self clean program every now and again, just to free the valve. I also think the extra performance (or at least doing away with the standard de-tune map) would probably keep the engine running cleaner anyway. |
Agreed ![]() The beauty of having the ATRIC is that you can put the tune back to "normal" for a week or so every now and again. Hopefully, that should keep the EGR valve etc. ticking over. Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
I can re-enable the self cleaning cycle if you wish? I just turn it off, because I can! ![]() |
Many thanks for the new map and great service. I will try it this morning and let you know how I get on ![]() As far as the turbo goes, it was probably a dud manifold in the first place - it's not uncommon. The whistling is only loud when the engine's quite hot, which won't happen that often during a Munich Winter! Anyway, when I'm sure it's the manifold (still haven't been bothered to look yet - cold outside), I will fit a Nak. gasket next year and "improve" (another) one of the things LR perhaps didn't quite get right ![]() Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Tim seymour Member Since: 17 Jan 2010 Location: Devonport TAS Posts: 92 ![]() ![]() |
hi my name is tim i have alive tune and checked last night and have po606 do you know what it is Cess the Taswegian |
Hi, From: http://bellautoservices.co.uk/?s=p0606&search=Search P0606 Engine control module (ECM) processor - circuit voltage below threshold ECM fault I also have that error code every now and then, nothing to worry about -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
