Home > Td5 > Landy went nuts after injector seals renew
Defender marto
United Kingdom 2004 Defender 90 Td5 HT Oslo Blue
Had the injector seals changed today. Picked it up after work and get about 1.5 mile down the road and I had a sudden partial power loss and I think the engine sounded noisy like a tappet had broke. Then I noticed the massive smoke screen I was creating followed by the engine revving up on its own and producing a heck of a lot more white smoke. So pulled over and turned off landy but still running so engaged first gear stepped hard on brake and let the clutch out and the engine stopped. Fortunately garage had not closed yet and came around and picked it up. I am thinkingthe fuel injector seal work has gone wrong somewhere. I even got lr parts to. I wonder if an injector had popped out or something might be the reason for the broken tappet noise. Garage said they will call me tomorrow. I'll update tomorrow.
Post #598667 2nd Feb 2017 7:05pm
LR90XS2011
hope its nothing major, mate had an engine do this with a holed piston! DEFENDER 90 TDCI XS,
Post #598673 2nd Feb 2017 7:32pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Not good....I hope a piston is not holed.
Read recently on here about people not properly draining the fuel prior to pulling the injectors for a seal change.
First Cylinder fills with fuel. All injectors changed, then hydro lock and mechanical damage to the cylinder/ piston that was first injector to be changed soon after start up...normally #1.
Here's hoping that is not what happened.
Post #598686 2nd Feb 2017 7:57pm
lightning
Did you replace the injector seals/washers because there was a fault, or just for routine maintenance?
I wanted mine changing when l got my 2005 TD5 two years ago, as a maintenance task.
My local lndy said best to leave alone unless there is actually a fault, as removing them can cause other issues and further problems. I tried to get two other LR specialists to do it but both said leave alone if it's running OK.
The lndy said the injectors "might not re-seal" and the LR dealer "you might end up needing a new head"
Although this is contrary to what l read on forums like this, where no real issues are reported from changing them.
Post #598700 2nd Feb 2017 8:30pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I hope it's just they have done a Censored job and not sealed one properly. It's then filled the motor with diesel and the oil level has gone up and it's started to run away by running on is own oil.
Caught quickly you shouldn't have damaged it. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #598799 3rd Feb 2017 12:00pm
Laurie
Hopefully just one injector stuck open.
'Hydraulicking' would sound lick a stuck valve.
Post #598800 3rd Feb 2017 12:08pm
Defender marto
That is what happened, an O ring had failed. I would not say they did a bad job it is just one of those things. I have used that garage for nearly 8 years. The landy is back now and running ok and they even steam clean the engine, that was a job I was going to do so saved me a job. And no charge for the rework. I get the impression that it is such a tight fit that O rings can get a bit damaged when putting injectors back in. It is probably why no one want to touch that job unless it was at fault which mine was, difficult to start when cold. Now it has new injector seals and new fuel pump as it was getting really noisy. marto
Post #598873 3rd Feb 2017 5:50pm
geobloke
Oh heck bad luck, I have not heard of the seals failing to that extent before. I suppose the seal in question could have been twisted during the fitment to the injector preventing it from sealing to the head adequately. Either way bad luck and I am glad it is sorted now. Thumbs Up
Post #598887 3rd Feb 2017 7:12pm
Justtellme
Very good news!
Glad it was not something catastrophic......
Patrick
Post #598969 3rd Feb 2017 11:20pm
gazman
make sure they changed the oil as the diesel makes the oil very thin. On a plus point it works like a engine flush and inside your motor will be sparkling 2014 - current ..... 2003 defender td5 90 (my car)
Post #598970 3rd Feb 2017 11:33pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
^^oh yes.
We used to add a 1/2ltr to 1 litre of diesel to the oil changes to clean up big diesel engines in construction plant.
It does a brilliant job.
Could they not put a thin smear of grease around the o-ring, or inside the hole. Not a dollop of grease, just a thin, thin smear. If nipping the o-ring was such a risk, why not?
What does the wsm say on this I wonder?
Andy
Post #598994 4th Feb 2017 7:39am
Defender marto
Yep I got an oil change thrown in to. 👍🏻
Post #599062 4th Feb 2017 1:59pm
NickMc
Always LIGHTLY lubricate O/rings. Always change the oil when you do the seals as it's impossible not to get diesel leaking.
Post #603221 20th Feb 2017 12:23am
