Home > Td5 > TD5 EGR Cooler Return Pipe |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 |
I removed the pipe. I was going to take it off all the way around to the 'what's its name' under the exhaust manifold -but as an interim step I just took it off to the fuel cooler.
1st Jan 2017 4:12pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2168 |
Remove the whole lot, use a bolt and a jubilee clip to seal up the coolant hoses in the short while. Long term you can remove the pipe that runs round the back of the engine to the oil cooler. You'll loose just under a litre of coolant capacity but nothing to be concerned with.
2nd Feb 2017 3:24pm |
