![]() | Home > Technical > Headlight Issue |
Almost certainly the switch on its' way out. As they take the full load of the lights, they have a habit of melting the contacts.
A brief search for headlight switch or similar will show it's a well worn path. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
I'd second that but I'll add, when you're replacing the switch, give a second thought to adding a relay circuit to the headlights like a Boomslang Loom or similar, it means then that the switch is only passing enough current to drive the relay coils and you also get more power to the lights themselves.
Brighter headlights on a Defender are never a bad thing. ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20620 ![]() ![]() |
^^^^ This is true, I've got Land Reiziger loom to fit to mine.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
