excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
MOT time......Failed....
Steering drop arm ball joint 2 x rear ARB links 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Hard luck John, if you can get a Discovery drop arm and change it for that, they're much easier to sort in the future, if you get caught out timewise to get the arb joints simply take the arb off as they can't test what isn't there. I've never had one fitted since it left the factory. It's like high level brake lights, if it's there and not working then it's a fail but if it's not there in the first place then they can't fail it
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1001 ![]() ![]() ![]() |
I also took my 90 in for MOT it passed with just 2 advisories not bad for a 17 yr old girl.
![]() Last edited by Oakseywick on 19th Jan 2017 8:33pm. Edited 1 time in total |
It was hard luck. Work done now by the garage. Rear ARB links I could have done/removed but not having a puller for the steering arm I would have struggled in the drive, in the cold! MOT, 2 x ARB links and Steering arm £230 with VAT.... Other than that an advisory on slightly frayed drivers seat belt. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 728 ![]() ![]() |
Hello,
Just wondering if I can use Jate rings on my defender if I brought some for recovery points Just wondering if they are strong enough for recovering other vehicles if I had a kinetic rope attached on aswell??? Also if they are good for recovering, what's the best way to fit them. MT Arran |
Hello,
Rewired the LED spot light plug so now both work.
Removed the old drivers door seal and replaced with a new Puma style one. (old square door frame) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 800 ![]() ![]() |
Today I broke down in my 90..
DG123 Member Since: 29 Aug 2015 Location: North West Posts: 135 ![]() ![]() ![]() |
Finally soldered the wire back onto the drivers heated seat back temperature controller. Hurrah for a bit more comfort on these chilly mornings
![]() 2003 D2 Td5 Black [SOLD] |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10872 ![]() ![]() |
Went greenlaning today with our little group and had a fantastic time
Clayton, Photos, or it didn't happen!
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
Also clayton where did you go? I'd be up for a spot of greenlaning if it's in Devon
![]() And non damaging ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Collected parts for a 90 from Andyred90
..., but was in the Disco ![]() ![]() |
Sorry GREENI its not going to happen as im very ![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
