Home > Puma (Tdci) > temp gauge loss of power |
Engine wiring loom chaffing on metal engine block
19th Jan 2017 6:37pm |
Assume the chaffing is upstream of the coolant temp sensor?
(which is where?) Solved the bowel problem, working on the consonants... |
19th Jan 2017 6:50pm |
mastertech Member Since: 19 Jan 2017 Location: manchester Posts: 5 |
It's not a coolant sensor fault in sdd it's saying loss of can , engine relay and incompatible software |
19th Jan 2017 8:05pm |
Please ignore if you know better but it was my understanding that DTC faults cant be guaranteed to be accurate. If a system is faulty the fault codes can be just as spurious as the symptoms..
Of course, even when they're wrong, they can provide helpful hints (as often as they give you red herrings). Solved the bowel problem, working on the consonants... |
19th Jan 2017 8:10pm |
coolant sensor is wired ECM
controller area network between ecm to instrument cluster battery light wired to instrument cluster Last edited by dorsetsmith on 19th Jan 2017 8:28pm. Edited 1 time in total |
19th Jan 2017 8:12pm |
19th Jan 2017 8:25pm |
No I agree it is wired in the ecm But the fault is communication to cluster via ecm I will check loom but was kind of hoping there was a tbs or something My apologies it posted twice am mobile at the moment |
19th Jan 2017 8:28pm |
thank you dorsetsmith is there any particular place they chaff ? |
19th Jan 2017 10:21pm |
