![]() | Home > Puma (Tdci) > temp gauge loss of power |
Engine wiring loom chaffing on metal engine block
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Assume the chaffing is upstream of the coolant temp sensor?
(which is where?) Solved the bowel problem, working on the consonants... |
mastertech Member Since: 19 Jan 2017 Location: manchester Posts: 5 ![]() ![]() |
It's not a coolant sensor fault in sdd it's saying loss of can , engine relay and incompatible software |
Please ignore if you know better but it was my understanding that DTC faults cant be guaranteed to be accurate. If a system is faulty the fault codes can be just as spurious as the symptoms..
Of course, even when they're wrong, they can provide helpful hints (as often as they give you red herrings). Solved the bowel problem, working on the consonants... |
coolant sensor is wired ECM
controller area network between ecm to instrument cluster battery light wired to instrument cluster Last edited by dorsetsmith on 19th Jan 2017 8:28pm. Edited 1 time in total |
No I agree it is wired in the ecm But the fault is communication to cluster via ecm I will check loom but was kind of hoping there was a tbs or something My apologies it posted twice am mobile at the moment |
thank you dorsetsmith is there any particular place they chaff ? |
