Home > Technical > Dim Dip
Page 4 of 4 <1234
timbar
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Cheers Phil and Marc -- I'll dig again tomorrow. I've already replaced the main headlight switch, so I'll strip the wheel back again and take a look at the switches.
After that I suspect I'll be hunting around for points where the circuit gets grounded and seeing if anything's loose. 2009 110 XS Station Wagon
Post #591103 7th Jan 2017 9:59pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
timbar, it wasn't the headlight switch that was the issue it was the flash and main beam part of the indicator stalk that was causing my issue which from memory was similar to your problem. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #591119 7th Jan 2017 10:23pm
timbar
Thumbs Up ta 2009 110 XS Station Wagon
Post #591172 8th Jan 2017 2:04am
Had a look today, unfortunately very busy today so that was about all I could do.
Not disconnected it yet, but will as soon as I get a chance, some proper light and it isn't bitterly cold out.
A real sod to take a pic of with an iPad but I took a pic of mine too.
Looks like an Econoseal connector.
 WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #592199 11th Jan 2017 6:10pm
Martin
Site Admin
It is indeed an Econoseal  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #592201 11th Jan 2017 6:13pm
Well today, call me a little OTT but I got a pair of Econoseal connectors to blank off the two connectors present for the resistor..
I just Silicone sealed the rear entry's for a waterproof connections and to keep everything dry and clean. Works a treat and all tidied up and out of the way.
All good, everything working as it should except for one thing.
Headlights are fine, no sidelight, dipped and full beam on either stalk pull back or constant on latched.
All good on the headlights in every way.
The issue, now my spotlights are main beam blue and white cable triggered by a Relay.
Pull the stalk back and the headlights will go main beam, the Relay will trigger and so will the spots Relay.
But the stalk forward to latch on and the headlights will go full beam but NOT the Relay trigger and thus not the spots.
On all occasions the dash main beam light will work.
So it seems that, I have suddenly got a dodgy spotlight Relay or the trigger feed voltage has changed.
There must be voltage present on pulling the stalk back on the trigger feed, but not on latching the stalk.
I cannot see why this is happening as the blue white main beam cable should be live on both main beam stalk pulled forward intermittent which it does AND latched on.
If this isn't the Relay which I can't see that it is then I'm wondering if when I get the Land Reiziger looms fitted I'll have issues just the same.
The Noldens I have to fit are dipped beam and main beam only via the H4 connector, the position lights. (Mine have these.)
Are fed from the sidelights above using the 4x4 Overlander loom.
I haven't done any testing or tried a new Relay but none the less I'm guessing the Relay will make no difference and the main beam pin on the H4 will be either low voltage or no voltage with the main beam stalk forward and latched.
I'm wondering on e the Land Reiziger looms are fitted if I can just tap into the main beam feed on that to the headlights and all will be well.
Otherwise I'll have a headache on my hands!
And probably will anyway. Rolling Eyes
**EDIT**
Just thought I'd pop out and try it with the engine running with alternator charging current.
Still the same.
I'm guessing it's 12.2v - 14.2v on main beam wire with stalk pulled to flash and low or 0v on latched constant.
Really odd, if I short the two I'll end up with dipped on sidelights and on sidelights which is not what I want.
Hmm, will need to do some testing... WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #593236 15th Jan 2017 3:59pm
After doing some research online, it seems it may be the dim / dip Relay too that could be a possibility.
Most mention earlier Defenders, but my 90 2.4 Puma has the same Relay as those suggested.
I'm wondering if this may be my issue:
https://locris.wordpress.com/2015/08/13/la...-solution/
At least temporary I can test for free and see how it goes.
Thoughts? WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #593265 15th Jan 2017 5:57pm
Steve,
You might want to take a look at my post here.
The dim dip relay cannot be the source of your problem. Simply unplugging the dim dip resistor cannot affect the main beam circuit in the way you describe.
Post #594148 18th Jan 2017 6:45pm
docperio44
Canada 2002 Defender 110 Td5 CSW Stornoway Grey
blackwolf wrote:
Not sure if the TD5 is the same as the Puma, but on my Puma I simply unplugged the resistor which is located in the o/s front wing tucked in more or less above the air intact hole in the wing panel. It's hard to see but easy to reach.
I need some help finding the resistor on the TD5, anyone?
Post #1003414 9th Aug 2023 3:12am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
The dimmer resistor on my Td5 was tucked in on the inner wing around or a little in front of the air intake on the right side front wing, same as the Puma.
Mine is a right hand drive car, I'm not sure if it's the same on a LHD.
Post #1003466 9th Aug 2023 2:03pm
Page 4 of 4 <1234
