Home > Technical > Dim Dip
Page 2 of 4 <1234>
MartinK
Blackwolf - I agree with all you say above.
Never liked dim dips, they draw the current, and reduce bulb life...where the benefit in that?
It's becoming a battle for brighter lights. Having hit a deer last year, I have been improving my lights (Philips Extrem bulbs) to give me better vis on dip beam (and may fit some driving lights before next winter on the Defender (I travel quite a bit in North Scotland)
However, there seems to be an increase in illegal and inconsiderate use of lights (Fogs, for instance should only legally be used when visibility is reduced to 100 metres or below...and then WITHOUT the dip beam ...the idea being that the fog lights stop light reflection in falling snow or thick fog... but no-one seems to actually know that!)
Quote:
They are intended for use at low speed to increase the illumination directed towards the road surface and verges in conditions of poor visibility due to rain, fog, dust or snow. As such, they are often most effectively used in place of dipped-beam headlamps, reducing the glareback from fog or falling snow, although the legality varies by jurisdiction of using front fog lamps without low beam headlamps.
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #107569 15th Dec 2011 10:53am
mfspannerman
United Kingdom 2002 Defender 90 Td5 HT Oslo Blue
What is the easiest way to dissable the dim dip on my land rover as i am getting fed up of keep changing head light bulds! Rolling Eyes
Thanks Make tracks and get moving!!
PUTTING FOOD ON YOUR PLATE IS WORTH THE WAIT! PLEASE BE PATIENT!
Post #192402 10th Dec 2012 5:59pm
Not sure if the TD5 is the same as the Puma, but on my Puma I simply unplugged the resistor which is located in the o/s front wing tucked in more or less above the air intact hole in the wing panel. It's hard to see but easy to reach.
Post #192440 10th Dec 2012 7:15pm
Td5 is the same ^^^^
Post #192632 11th Dec 2012 7:48am
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
That's interesting. I didn't realise this feature was ever fitted to the Puma. Maybe it was dropped early on as I'm sure that mine doesn't have it.
Pete
Post #192698 11th Dec 2012 12:11pm
Pete
It was fitted to the "more commercial" versions at least in the early days. You either had the headlamp adjuster (on "non-commercials" such as the SW) or dim dip (on "commercials" such as the DC). My '07 DC had dim dip.
Not sure what happened later on when they all became Euro Class N rated.
Post #192708 11th Dec 2012 12:44pm
mfspannerman
thank you all for your help that worked and now dim dip doesn't! Very Happy Make tracks and get moving!!
Post #192775 11th Dec 2012 5:28pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Any chance someone could post a photo showing where this resistor lives, I've looked on mine (TD5) and I cant see it Big Cry Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #192961 12th Dec 2012 4:34pm
It's in a place where it cannot be photographed, unfortunately. It is somewhere between the radio aerial and the plastic cover on the o/s from wing upper surface, inside the wing. A torch and mirror may allow you to see it.
Assuming, of course, that you have one and it is in the same place!
Post #192973 12th Dec 2012 5:31pm
taffrican
Thank you mr wolf, I will look tomorrow Thumbs Up too cold and dark to look now! Optimists say the glass is half full..
Post #192974 12th Dec 2012 5:34pm
ZeDefender
Sorry (as always) for my stupidity but can I be certain that with a "European" Puma SW (2011) I don't have one of these things? Tell someone you love them today because life is short.
Post #303839 31st Jan 2014 5:39pm
ericvv
^^^Same question here. Would a 2009 model (produced August 2008) left hand drive non-UK Station Wagon have such a resistor installed? In any case I never had that dim dip function, and I also have the electric headlamp adjuster on mine.
Asking this, because shortly I will have my lighting loom adjusted to channel the headlight power direct from battery to lamps without passing in full force via the light switch. And in a different thread here some remarks were made that if there is a dim dip resistor, it might cause some headaches to this adjusted loom installation working properly.
So if anybody can confirm would be much appreciated.
Tks, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #303977 1st Feb 2014 6:19am
landy andy
The easiest way to tell if you have dim dip is to have engine running, put side lights on. If you have NO illumination in headlights, you don't have dim dip. If you have a dull glow from the headlight you HAVE dim dip.
My 10 reg double cab has dim dip. But not really concerned as I never use side lights. Lights either on or off.
Andy
Post #303985 1st Feb 2014 8:09am
ericvv
Tks Andy, as already said I don't have dim dip. Just wondering if they still installed that resistor in the loom somewhere, just like Defenders often have wiring installed for certain factory options which were not ordered and not installed. (like for loudspeakers and radios, etc....)
Post #303987 1st Feb 2014 8:26am
munch90
the resister is plugged in to the loom not part of the loom .so guess it would not be fitted if not used
Post #303993 1st Feb 2014 8:58am
Page 2 of 4 <1234>
