Home > Technical > Puma EGR valve clunking |
The one option I know of isn't cheap but you do get a whole host of other benefits:
https://secure.bellautoservices.co.uk/stor...biography/ Otherwise known as a 'remap' by BAS - quite a game changer in terms of driving. Pete is a site sponsor, check out the sub forum for discussion... Solved the bowel problem, working on the consonants... |
11th Jan 2017 4:53am |
p.s.
If by 'clunk' - you mean "chacka chacka chacka" - then yes that's the EGR. If you really mean 'clunk', then it's likely something ain't right. Solved the bowel problem, working on the consonants... |
11th Jan 2017 4:54am |
Taffy1 Member Since: 11 Jan 2017 Location: Bath Posts: 4 |
It's definately the Chaka Chaka Chaka
11th Jan 2017 8:28am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20433 |
That is normal EGR function, if you run some Millers diesel additive you may find it'll soften in ipits operating sound and possibly give it somewhat of a clean.
Mine is blanked and will never be an issue to me with an Alive stage 1 tune. It will cause you problems one day both in performance and putting the dash light on $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
11th Jan 2017 11:52am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
Mine's intermittently playing-up. It's OK just now but I am hardly using her as I'm tied-up with other things (semi-mothballed just now)
This is one thing that can happen when they play-up http://www.defender2.net/forum/topic49367.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
11th Jan 2017 2:39pm |
