Home > Technical > Puma EGR valve clunking
Taffy1
When I switch off my 2010 puma defender 90 there is a clunking noise. I'm told it is the EGR valve. Is this normal . Can I get rid of the noise. Thanks
Post #592000 11th Jan 2017 12:45am
agentmulder
Kuwait
The one option I know of isn't cheap but you do get a whole host of other benefits:
https://secure.bellautoservices.co.uk/stor...biography/
Otherwise known as a 'remap' by BAS - quite a game changer in terms of driving.
Pete is a site sponsor, check out the sub forum for discussion... Solved the bowel problem, working on the consonants...
Post #592004 11th Jan 2017 4:53am
agentmulder
Kuwait
p.s.
If by 'clunk' - you mean "chacka chacka chacka" - then yes that's the EGR.
If you really mean 'clunk', then it's likely something ain't right. Solved the bowel problem, working on the consonants...
Post #592005 11th Jan 2017 4:54am
Taffy1
It's definately the Chaka Chaka Chaka
Post #592034 11th Jan 2017 8:28am
That is normal EGR function, if you run some Millers diesel additive you may find it'll soften in ipits operating sound and possibly give it somewhat of a clean.
Mine is blanked and will never be an issue to me with an Alive stage 1 tune.
It will cause you problems one day both in performance and putting the dash light on $W33T $0U7H3RN $UG4R
Post #592096 11th Jan 2017 11:52am
MartinK
Mine's intermittently playing-up. It's OK just now but I am hardly using her as I'm tied-up with other things (semi-mothballed just now)
This is one thing that can happen when they play-up http://www.defender2.net/forum/topic49367.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #592151 11th Jan 2017 2:39pm
