Home > My Defender > What Did You Do In Your Defender Today |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 |
Yeah - spotted a trail of water from the lower nut on the driver's side. In addition, the washer on the lower nut showed the beginning of corrosion - other 2 nuts & washer are fine. Will see what happens. If this does not work, might be the Naka double door seals would be a worthwhile investment. 2001 TD5 110 DCPU in Bonatti Grey |
14th Feb 2011 12:00am |
G4sweep Member Since: 24 Sep 2010 Location: Paderborn Posts: 182 |
A solution to footwell rain!? I'll give this a shot. Many thanks for the info. Sweep
2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW |
14th Feb 2011 12:47pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Changed the track rod I bent last week for one of Gwyns heavy duty ones
Click image to enlarge |
14th Feb 2011 12:53pm |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 |
A combination of Weetabix and Spinach (and no hangover) |
14th Feb 2011 2:23pm |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
PICKED IT UP
Been without it for what seems like weeks! After putting quite a lot of miles on the courtesy F2 in comfort, I've had to re-deform to fit the Defender but it feels like home again! Like being inside an old friend, so to speak.... It's had a new gearbox and output shaft, roof has been touched up where the paint was peeling and the wing mirror arm has been replaced, so hopefully that will be the end of all it's issues now Wasn't able to take the long route home (valentines day or something... pfft) but I'm in Liverpool tomorrow and Whitby later this week so that'll make up for it! |
14th Feb 2011 6:13pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
Myself and my sales guy took a D4 on a 500 mile round trip today as J-Lo is at the doctors. This is the first time my sales guy has been in a D4, get this, about 30 miles into the trip he turned to me and said "The blue Land Rover is a lot more comfortable isn't it" I had to agree the D4 rocks side to side quite a bit. 130's have feeling's as well you know
14th Feb 2011 6:59pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Mine were leaking there got the dealer to get some more gaskets fitted seems ok now |
14th Feb 2011 8:19pm |
I have the same problem going from mine to the wifes D4 i even complained to the dealer saying there is something wrong with the D4 steering its just so sharp the slightest movement and your off were the 130 has a bit of play which is fine |
14th Feb 2011 8:24pm |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 |
Fitted a Mantec rear window Guard, just waiting for my new wheels
15th Feb 2011 11:35am |
Fitted a few wee bits n bobs ordered from Mud - only placed it yesterday afternoon, got here first thing this morning.
Planning on the great ICE install now. 2001 TD5 110 DCPU in Bonatti Grey |
15th Feb 2011 11:36am |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 |
ordered some carpets from Britpart and waiting for them to arrive soon.....
15th Feb 2011 11:38am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Rope You can swing a tyre onto your shoulder and pass it up to someone who's already up there but if you're on your own, haul it up. Never drop a tyre off the roof - it'll bounce very high and is lethal One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
15th Feb 2011 6:18pm |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
Tack how did you fit the guard? Did you rivet it in place? Russell Russell 2011MY 110 XS USW Black |
15th Feb 2011 6:43pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
makes sense, not sure i would want that amount of weight that high up. always wondered how a fully spec'd Defender would react with loads of weight in it and on the roof. having seen some of the Camel videos they seem very unstable BM52 |
15th Feb 2011 9:59pm |
