![]() | Home > My Defender > What Did You Do In Your Defender Today |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
russ it comes with 8 or so screws to fix it. it really did take 5 minutes ![]() |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 ![]() ![]() ![]() |
fitted some front HD springs ...
in this pic you can see a little diference ... ![]() Click image to enlarge but in these you can see some diference ... ![]() Click image to enlarge ![]() Click image to enlarge but I'm happy with the result ! Between winch (5o kg) and bumper (more 25 kg than standard) plus protections (+- 15 kg) plus all the bits I still want to add ... these will do ! And the 110 is now leveled ... for now ! ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
MK the picture is reversed.....note the fuel filler also..... ![]() |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 ![]() ![]() ![]() |
![]() 2011MY 110 XS USW Black |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
Bonnet stickers also gone or put on
![]() Question. If you have a snorkel fitted would the air intake on top of the wing not be sealed shut as well, or doesn't it matter? |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
The intake on the wing is for the air into the cab
Nice eyes! ![]() ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2456 ![]() ![]() ![]() |
So you kept the OE shoxs. I bet you it does not feel a lot more stiff. The lift is about 1"? Puma 110" SW
It's not a lift ... it's standard LR springs, but Heavy duty ones... NRC9448 and NRC9449, as I had the standard springs. It's now a lot more stiff, and the wheels tend to bounce less when I pass a bump ... As I usually don't carry any weight in the back I'll keep the standard ones there ... But the 110 is now leveled ... I'm happy with the changes! ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
So they are a bit shorter then? Puma 110" SW
no...don't think so ... they're heavier ... but next to each other they're about the same height ... It's a diferent rate ...don't know much about springs, but it seems to me that the steel is thicker on the HD ones ... maybe that's why tey're havier ... Regards
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
Managed to get the rear, very rusty, light guards off! What a
![]() The guards have been on the truck since new and were looking in a right mess, powdercoat hanging off and rust showing through underneath. The self tappers had seized up nicely, got 5 out with sheer brute force (thought I was going to pop out a blood vessel or loose a struggling string) , one had to be drilled out (got to use my shiny new Makita combi) ![]() ![]() ![]() All is now nicely tidied up with a set of A4 stainless M5 bolts and washers. The back end looks transformed ![]() Great offer on the Makita BTW at Screwfix ![]() http://www.screwfix.com/prods/84044&cm...Y?ts=54525 |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 ![]() ![]() ![]() |
Fitted the overhead flip down DVD system with LEDs & wireless headphones & game controller - all for the kids
![]() Click image to enlarge And then an in dash DVD / GPS / Hard Drive system for me! ![]() Click image to enlarge[/img] Now on to some bling from Entreq, and then the EGR kit from Alive. It really does never end, this Landy obsession..... 2001 TD5 110 DCPU in Bonatti Grey |
EGR Kit from Alive now fitted. Will see if any noticeable difference in performance over next week or so.
Amazing what you find when doing this sort of thing. Am a complete mechanical novice - the last time I remember mucking around in an engine bay was alternator replacement in my old Volvo 340DL when I was 17. It seems like a previous owner of my Landy had a new EGR fitted at some point. Hence removal of EGR from manifold to fit blanking plate was tricky, given that previous owner had already had to drill out old bolt & re-thread with larger size, plus fitting new bracket to engine. Alive make a nice kit - simple & well made. ![]() Anyway, all out now, and put into the big pile of "used to be in the Landy" bits ![]() |
