Home > Tdi > rebuild or replace 300tdi engine
Jonathan111
Hello all - after 2 years of no trouble from my 1998 110, looks like an overheated 300tdi engine needs a rebuild or replacement. No idea what happened - was clipping nicely along the motorway, only odd thing was the temp gauge stuck hard on cold after 40 miles, then smoke, steam and no power. Into the hard shoulder and no dice when I tried the ignition, nothing. Turns out two pistons have melted and jammed in the cylinders - very messy. I'm in a dilemma of getting my garage to rebuild it or get a reconditioned one off ebay and having that put in, but the original cause - cooling system? - will have to be sorted out. Could theoretically put a new engine in myself, but a bit of a novice really. Wondering if anyone has any thoughts on how /where to get a recon engine (apart from ebay) - Turner Engineering will do a service exchange for 2695 ex VAT, slightly above my budget. Then again, maybe the garage can rebuild for a reasonable cost. Its a piece of string length question I suppose, will get the full quote breakdown tomorrow.Any thoughts gratefully received, cheers, Jonathan
Post #589865 3rd Jan 2017 8:02pm
miker
My defender, under it's previous owner, had a pair of TD5 engines from turner fail. For that reason I personally wouldn't go near them.
The rebuild could be an option, but it sounds like it's a pretty major failure. I'd look into a 2nd hand engine personally, if you have an engine crane and some friends, a defender engine swap isn't too hard!
Post #589867 3rd Jan 2017 8:11pm
g-mack
curious, what went wrong with the two turner engines? My 109 thread
my youtube channel
Post #589899 3rd Jan 2017 9:27pm
Retroanaconda
Get a second hand engine, ideally one you can test before removal from the donor, and swap it out. That'll be the easiest route, and likely the cheapest. As above with a few mates an engine swap makes for a pleasant days work if all goes to plan.
Fit a coolant level sensor when you do, 300Tdis suffer from a design fault whereby the water pump is mounted very high on the engine, meaning a relatively slight drop in coolant level can end up with the pump dry (and temp sender, hence reading cold) and very quickly a Censored engine. A sensor will notify you that you have a leak.
Post #589901 3rd Jan 2017 9:28pm
miker
First failed with I think loose head bolts after ~5k. Was replaced under warranty.
Second threw it's timing chain after 2 years & 20k. THis was while I had it. Research and stripping it down makes me think it may have been the oil pump sprocket bolt in the timing case.
Post #589932 3rd Jan 2017 10:32pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
I'd source a second hand engine from a rotten disco- they can still be sourced complete for 5-700 quid, keep axles and transfer box from it too to sell or keep. They are straightforward to do, it's only nuts and bolts Rolling with laughter the engines are the same btw, not like the 200's..
Cheers. Alex 98 300 tdi 90 project
94 Range Rover vogue 4.2 lse
79 911 sc
08 130 double cab utility
Post #589972 4th Jan 2017 1:10am
g-mack
ah thats not good!
i have always heard good things about Turners! My 109 thread
my youtube channel
Post #589994 4th Jan 2017 8:37am
L110CDL
My thoughts are the same as g-mack's Rolling Eyes 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #590210 4th Jan 2017 8:38pm
miker
So were mine, and I know many people who have had very good experiences of them. Unfortunately mine weren't so positive!
Post #590222 4th Jan 2017 9:02pm
L110CDL
So that got me thinking what the statistic's would be between the " good and bad " engines Rolling Eyes 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #590227 4th Jan 2017 9:06pm
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
First sign of low coolant is no heater.. to melt 2 pistons it musta been a helva noise also, Shocked Yeh go for another engine, thers lots about, I have a 80k mile disco 300 engine here,. I"v just used the ancileries of it, .
pity you were so far away,
Post #590236 4th Jan 2017 9:22pm
Jonathan111
yup, the heater had stopped, figures, thanks - an education! cheers, J
Post #590351 5th Jan 2017 12:11pm
Jonathan111
thanks all for generous and useful contributions, the research goes on, but suspect it will be a recon engine rather than a rebuild in the end, cheers, Jonathan
Post #590354 5th Jan 2017 12:14pm
