Home > Tdi > rebuild or replace 300tdi engine |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
My defender, under it's previous owner, had a pair of TD5 engines from turner fail. For that reason I personally wouldn't go near them.
The rebuild could be an option, but it sounds like it's a pretty major failure. I'd look into a 2nd hand engine personally, if you have an engine crane and some friends, a defender engine swap isn't too hard! |
3rd Jan 2017 8:11pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
curious, what went wrong with the two turner engines? My 109 thread
my youtube channel |
3rd Jan 2017 9:27pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2640 |
Get a second hand engine, ideally one you can test before removal from the donor, and swap it out. That'll be the easiest route, and likely the cheapest. As above with a few mates an engine swap makes for a pleasant days work if all goes to plan.
Fit a coolant level sensor when you do, 300Tdis suffer from a design fault whereby the water pump is mounted very high on the engine, meaning a relatively slight drop in coolant level can end up with the pump dry (and temp sender, hence reading cold) and very quickly a engine. A sensor will notify you that you have a leak. |
3rd Jan 2017 9:28pm |
First failed with I think loose head bolts after ~5k. Was replaced under warranty. Second threw it's timing chain after 2 years & 20k. THis was while I had it. Research and stripping it down makes me think it may have been the oil pump sprocket bolt in the timing case. |
3rd Jan 2017 10:32pm |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 724 |
I'd source a second hand engine from a rotten disco- they can still be sourced complete for 5-700 quid, keep axles and transfer box from it too to sell or keep. They are straightforward to do, it's only nuts and bolts the engines are the same btw, not like the 200's..
Cheers. Alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
4th Jan 2017 1:10am |
ah thats not good! i have always heard good things about Turners! My 109 thread my youtube channel |
4th Jan 2017 8:37am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10742 |
My thoughts are the same as g-mack's 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
4th Jan 2017 8:38pm |
So were mine, and I know many people who have had very good experiences of them. Unfortunately mine weren't so positive!
4th Jan 2017 9:02pm |
So that got me thinking what the statistic's would be between the " good and bad " engines 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
4th Jan 2017 9:06pm |
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 |
First sign of low coolant is no heater.. to melt 2 pistons it musta been a helva noise also, Yeh go for another engine, thers lots about, I have a 80k mile disco 300 engine here,. I"v just used the ancileries of it, .
pity you were so far away, |
4th Jan 2017 9:22pm |
Jonathan111 Member Since: 22 Jan 2015 Location: London Posts: 67 |
yup, the heater had stopped, figures, thanks - an education! cheers, J
5th Jan 2017 12:11pm |
thanks all for generous and useful contributions, the research goes on, but suspect it will be a recon engine rather than a rebuild in the end, cheers, Jonathan
5th Jan 2017 12:14pm |
