![]() | Home > Tdi > rebuild or replace 300tdi engine |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1768 ![]() ![]() ![]() |
My defender, under it's previous owner, had a pair of TD5 engines from turner fail. For that reason I personally wouldn't go near them.
The rebuild could be an option, but it sounds like it's a pretty major failure. I'd look into a 2nd hand engine personally, if you have an engine crane and some friends, a defender engine swap isn't too hard! |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
curious, what went wrong with the two turner engines? My 109 thread
my youtube channel |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2693 ![]() ![]() |
Get a second hand engine, ideally one you can test before removal from the donor, and swap it out. That'll be the easiest route, and likely the cheapest. As above with a few mates an engine swap makes for a pleasant days work if all goes to plan.
Fit a coolant level sensor when you do, 300Tdis suffer from a design fault whereby the water pump is mounted very high on the engine, meaning a relatively slight drop in coolant level can end up with the pump dry (and temp sender, hence reading cold) and very quickly a ![]() |
First failed with I think loose head bolts after ~5k. Was replaced under warranty. Second threw it's timing chain after 2 years & 20k. THis was while I had it. Research and stripping it down makes me think it may have been the oil pump sprocket bolt in the timing case. |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 725 ![]() ![]() ![]() |
I'd source a second hand engine from a rotten disco- they can still be sourced complete for 5-700 quid, keep axles and transfer box from it too to sell or keep. They are straightforward to do, it's only nuts and bolts
![]() Cheers. Alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
ah thats not good! i have always heard good things about Turners! My 109 thread my youtube channel |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10867 ![]() ![]() |
My thoughts are the same as g-mack's
So were mine, and I know many people who have had very good experiences of them. Unfortunately mine weren't so positive!
So that got me thinking what the statistic's would be between the " good and bad " engines
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 ![]() ![]() ![]() |
First sign of low coolant is no heater.. to melt 2 pistons it musta been a helva noise also,
![]() pity you were so far away, |
Jonathan111 Member Since: 22 Jan 2015 Location: London Posts: 67 ![]() ![]() |
yup, the heater had stopped, figures, thanks - an education! cheers, J
thanks all for generous and useful contributions, the research goes on, but suspect it will be a recon engine rather than a rebuild in the end, cheers, Jonathan
