Home > Maintenance & Modifications > LightForce HTX230 Hybird |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
Hi Steve , there are conversion sites for candela to lumens.
Have a look here Now this calculation is very sensitive to the apex angle. 382600 candela at 5 degrees is equivalent of 1965 lumens 382600 candela at 10 degrees is equivalent of 7856 lumens 382600 candela at 15 degrees is equivalent of 17763 lumens. So calculation is very sensitive to apex angle. Now we run light force on one of our vehicles. Now it eyeballhas a different colour temperature being more yellow then LED light. So using my rather old Mk 1 eyeball (extremely scientific, NOT) I would say that the light force lights are at or below the lower figure above. HTH Brendan |
2nd Jan 2017 6:14pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 922 |
an incandescent 100watt will produce about 1600 lumen output.
BUT Don't confuse a simple lumen figure as a basis on choosing a light, a lot of these figures are banded about as a quick way to impress and IMHO partial mislead into believing it is a true comparison to determine overall performance. Look for and as I did above for photometric data charts using Lux readings to give a proper comparison. If a manufacturer has included these then you can compare fairly. Use this site >> http://www.theledlight.com/lumens.html Digest the info and you can see there is a difference and drawing on that information you can rightly say just using a lumens figure doesn't take account of the design of the light and the quality of the reflector, Ultimately a very crucial part of the overall make up and performance of the light you see in the real world. |
2nd Jan 2017 6:22pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20580 |
Devon-Rover - Thank-you for the info.
Just one of the many reasons to avoid cheap eBay items and stick to good brands, most eBay ads as you say just give impressive figures. When it comes to, current draw is lower than specified the driver is poor quality and output is often way below that is stated KEEP CALM AND Drill ON 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
2nd Jan 2017 6:39pm |
The Roo's are a good light and IMHO pound for pound on the Lf 140's for performance. I did toy with the concept of changing them to HID too but alas never found them that lacking in performance to spur me into doing it. and ultimately I only sold them when I upgraded from the Roo - Lazer ST8 combo to a single Triple R 1000.
And your right with the cost I remember the first one's I got were about £70 each and no one else had brought them from my local supplier. I think they are about £100 each. |
2nd Jan 2017 7:02pm |
Aren't the LF 140's slightly smaller and 55w or so?
I'm looking around at HID kits now, many seem concentric to LF 240's though. Personally I can't see any difference in them except for differences in reflector sizes. KEEP CALM AND Drill ON 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
2nd Jan 2017 7:11pm |
Typo on my part I meant the 170's
I do have this in my bookmarks which I kept for further info should I have continued on the Roo HID conversion. http://www.expeditionportal.com/forum/thre...s-of-Pics) |
2nd Jan 2017 7:29pm |
I'll have a read now, thank-you once again. KEEP CALM AND Drill ON
2nd Jan 2017 7:49pm |
In last 10 years the exchange rate of AUD 2.5 to a low of 1.46 AUD to £
In last year the exchange rate has dropped from about 2.07 AUD to current 1.7 AUD to £ That is about a 20% decrease in exchange rate with AUD which is compatible to the USD, Euro etc Cost of shipping a container has gone up by about £2,000. So it is hardly surprising about price increases. With LED grades just have a look here This will give you a rough idea about the range of properties that LEDs have. Just saying that the LEDs used by any particular LED lightbar manufacturer comes from a well respected LED maker does not mean it is one of their higher end grades of LED. I have not looked into who actually makes the drivers which actually powers the LED. If there are large price differences between similar sounding/looking lights maybe this explains some of the differences. Isolux graphs can be useful however having the diagrams taken out to 0.25 lux is in my mind stretching it a bit in my mind. At 60mph, twice your stopping distance is about 150 metres , 300 metres is about the distance you will travel at 60mph in 10 seconds. So when looking at isolux diagrams consider the width and contours up to about 300 metres max. Brendan |
2nd Jan 2017 8:23pm |
Brendan -
Devon Rover - Having spent a couple of hours this evening looking at all this and your link. The info contained on that link has been invaluable and very helpful. Now following on from that, I have found on eBay this: http://www.ebay.co.uk/itm/Lightforce-240-B...xyzi9SkHrs This adapter appears to void any modifying required and fits LF 140 / 170 / 240. At least prevent modifying the mount at least anyway. Not overly cheap as such and would need importing this including a delivery wait. May need a thread tapping on it, I don't currently have tap and dies and would need some screws too. But on the whole a good find. If anything went pear shaped I'd still have the original holders untouched too. There are various HID kits around, el' cheapo and quality brands ranging from 50w to 120w for good prices. My wiring I have I set up for 100w each Halogen, Relay I think is 30A or 40A one of the two can tquite remmeber. Draw currently is 100w, 16A a pair or there abouts. 120w HID's draw around 20A a pair. My wiring I used is overkill gauge I think 3mm primary power feeds rated up to 33A or more. (Inc taking into account losses etc too) So current set up can take it no problem at all. Looks like a good option to consider, something I will look into after sorting Noldens and looms etc. It looks like shortly I'll have a lot of bits and pieces to wiring and in time plan a comprehensive wiring job to fit two fuse boxes. (BlueSea) So thank-you for all your input to everyone who has contributed, and I will update in time. KEEP CALM AND Drill ON 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
2nd Jan 2017 9:10pm |
