Home > Td5 > Miles from fresh tank?
Page 3 of 7 <1234567>
grafty99
Well call me a liar if you want but I can get 400 miles from a tank. What do I have to gain by lying about it?
Currently on 205 miles with way more that half a tank indicated......
 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #589096 31st Dec 2016 9:10pm
Morepower
New Zealand
OK... So not a TD5... But I have to agree with Grafty... Our 2016 2.2 TDCi 90 will do close to 400 on a tank... JUST!!!
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #589179 1st Jan 2017 12:44pm
isacs
Grafty....you running regular diesel or high quality?
Post #589193 1st Jan 2017 2:39pm
grafty99
I run standard diesel with 350ml of two stroke oil per tank.
I use Shell v-power or BPultimate when I need fuel near one of the two. None near home though so mainly texaco + 2 stroke oil which is our nearest Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #589198 1st Jan 2017 3:08pm
ibexman
Grafty how many miles after fuel light comes on do you fill up
Post #589199 1st Jan 2017 3:08pm
grafty99
Light usually on at about 370 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #589200 1st Jan 2017 3:09pm
grafty99
So around 30 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #589201 1st Jan 2017 3:10pm
barbel jim
you sure you've not turned into Miss Daisy ??? Rolling with laughter I'm be halfway through my 2nd tank Rolling with laughter Rolling with laughter
Post #589211 1st Jan 2017 3:41pm
Anderzander
That is remarkable.
Post #589215 1st Jan 2017 4:05pm
grafty99
Don't worry I still get a wriggle on when the occasion calls Wink 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #589218 1st Jan 2017 4:17pm
mactheknife
United Kingdom 2004 Defender 110 2.5 TD CSW Baltic Blue
Grafty, why do you add the two stroke oil?
Post #589221 1st Jan 2017 4:31pm
barbel jim
using the 2.2 everyday means when I am allowed the TD5 I'm a kid in a sweet shop Mr. Green The noise Whistle
Post #589222 1st Jan 2017 4:32pm
grafty99
The noise is very addictive, it does take quite a bit of self control Twisted Evil
I add 2 stroke oil because current low sulfur diesel has very few lubricating properties. The 2 stroke oil lubricates everything from the fuel pump to the injectors.
I notice much smoother and quieter running with the 2 stroke oil. If you have a search on Google I'm sure you will find a much more technical explanation than mine. Just clicked over 117k miles on the original fuel pump so it must do something as Td5 fuel pumps aren't the most reliable Rolling Eyes 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #589225 1st Jan 2017 4:57pm
keith
http://www.defender2.net/forum/topic29456.html
Oh hear we go again .........
" did you hear that 600 miles is possible in a defender "
Post #589235 1st Jan 2017 5:24pm
Anderzander
I'm surprised that it works out to be 30mpg - that's what I'm getting, but my light comes on at 330 and the most I've put in is around 55 litres..... so maybe if I kept going I'd get 400 too?
Have you ever run out of fuel? Or suffered from crap in the bottom of the tank with running it so low?
Post #589238 1st Jan 2017 5:39pm
