![]() | Home > Puma (Tdci) > odd brake issue |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
is your brake fluid level correct? I had brake pads replaced back in the 90's and when they pushed the pistons back they never took out the excess brake fluid. It gave it nowhere to expand too and they would drag.
That's when I started to learn how to fix them myself 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
dudley472 Member Since: 15 Nov 2012 Location: wolverhampton Posts: 96 ![]() ![]() ![]() |
yeah the fluid is fine, only done it a couple of times, its the ignition on /off thing curing it that has me stumped
ABS fitted ?
yes mate, abs
Ignition on /off thing curing it do you stop engine or is it still running ?
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 ![]() |
Brake servo issue possibly, if they start to fail internally it can cause the actuator rod to press on the master cylinder piston.
I stop the engine wait a few seconds turn it back on and it's cured, it's under warranty but wondered if anyone has seen this before, it can go for ages and not do it, the dealer could have it for weeks and it could be fine
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
Once problem has been fixed by turning if engine presumably it reoccurs after first use of breaks again? Everytime? Cheers
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 720 ![]() ![]() |
Interesting topic, i have an intermittent squeak on my 110. Checked the brakes for wear, no issue. but my girl suffers from an odd squeak and irregular times. No issues with efficiency.
next step, Im going to check the hand brake. |
No James, this is a random issue, most of the time its absolutely fine, just seems to happen as and when it feels like it, its under warranty but if I take it to the dealers and it doesn't do it what can they do in all fairness I just wondered if anyone else had had this, when its happening I've stopped and all the discs are warm to the touch all feel about the same temperature
if its all four then its not wheel station related which means further up the system.
the only thing engine related is the vacuum for the servo pedal returns to normal height? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
I had a similar problem when I changed the front pads and retaining pins etc. on the front wheels . It took me a while to find out that the pads were sticking on the pins when warm and not moving back with the pistons. I just applied a very small amount of anti squeal paste into the holes which sorted it out. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
i was thinking of warn pins holding pads in or similar but then thought could that be all four at once? Cheers
Doubt it James, its only done 18k, its all a bit strange, not happened since
