Home > Puma (Tdci) > Cold radiator, Hot pipework & header tank.. |
1. Thermostat no open ?
2. Coolant pump ? 3. block rad ? |
16th Dec 2016 6:19pm |
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 124 |
Top radiator hose is hot that means the thermostat is opening doesn't it as it's getting hot up to the radiator. Whole of the rad and bottom hose is cold meaning rad blocked inside??
16th Dec 2016 6:31pm |
below you will find link to work shop Manuel TDCI 2.4 07 >
https://1drv.ms/b/s!AtZSoWFHDgnGhQoLf-ZCjkI5M0R7 have be trying to find cooling flow diagram for the puma 2.4 but only find TD5 as the Thermostat and are the same |
16th Dec 2016 7:15pm |
Thanks for the link, just read how the cooling system works and sounds just like the thermostat isn't opening as the coolant get to the radiator without passing through the thermostat on these engines unlike 200tdi/300tdi units.
Thanks |
16th Dec 2016 7:36pm |
at lest to much of a job,
16th Dec 2016 7:44pm |
Thermostat changed today, happy days..
17th Dec 2016 6:42pm |
good new
17th Dec 2016 7:25pm |
