![]() | Home > Puma (Tdci) > Cold radiator, Hot pipework & header tank.. |
1. Thermostat no open ?
2. Coolant pump ? 3. block rad ? |
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 140 ![]() ![]() ![]() |
Top radiator hose is hot that means the thermostat is opening doesn't it as it's getting hot up to the radiator. Whole of the rad and bottom hose is cold meaning rad blocked inside??
below you will find link to work shop Manuel TDCI 2.4 07 >
https://1drv.ms/b/s!AtZSoWFHDgnGhQoLf-ZCjkI5M0R7 have be trying to find cooling flow diagram for the puma 2.4 but only find TD5 as the Thermostat and are the same |
Thanks for the link, just read how the cooling system works and sounds just like the thermostat isn't opening as the coolant get to the radiator without passing through the thermostat on these engines unlike 200tdi/300tdi units.
Thanks |
at lest to much of a job,
Thermostat changed today, happy days..
good new
