Home > Puma (Tdci) > Heated door mirrors
jst
Heated door mirrors
Any got any experience of them, recommendations? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #57572 7th Feb 2011 9:36pm
markb110
Hi
I have had the inserts that sit behind the exisiting glass on my last Defender and work were very effective (Bolt on Bits/ Mud Stuff) Only issue was when you break a mirror you have to buy two replacement pads as they are only sold as a pair.
For my 90 i went for a set of Spafax unbreakable heated mirrors from Bearmach. Again they work fine and very useful not just for clearing ice but also great for clear drizzle. Finally peace of mind when laning.
I have wired them to the rear heated screen to save on additional switches
Hope useful
Mark
Post #57577 7th Feb 2011 9:45pm
WarPig
These are ready made, but expensive compared to DIY.
http://cgi.ebay.co.uk/Land-Rover-Defender-...35af87c55e
Post #57582 7th Feb 2011 10:00pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
I made my own mirrors, was a bit fiddley.
Getting the cable through the spring part took ages, so £60 seams fair to me!
The parts must cost £40.
If you read the devon 4x4 wirte up....
http://la7dja.org/defender/mirror-heating/
When you make the groove for the cable into the hinge, make the groove a bit bigger or the cable will be crimped and eventually brake.
Post #57639 8th Feb 2011 8:39am
22900013A
Landrover is really behind the game by not offering these off the shelf. They would be one of the first mods I would make to a Defender. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #57739 8th Feb 2011 5:05pm
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
I made this mod on my Td5 last year. few meters of cables, a relay, 2 heating sticker that i got from ebay for 5 pounds or so and the advices of a good man from the forum (diesel_jim). It took me less than 3 hours overall to have it fitted. Yes the dashboard on the Td5 is much simpler to open than the Puma one but as soon as the weather improves i am going to do it on the Puma as well.
I promise this time i'm going to document it.
Post #57920 9th Feb 2011 8:33am
Merlin
I used these, ok so they restrict visibility but they're cheap.
Merlin
Post #58093 9th Feb 2011 6:35pm
SJM
Laughing Simon
'11 Defender 110XS Utility SW
'07 Discovery 3 HSE
'58 Porsche 356A (not good off road)
'59 Lambretta (not good on or off road!)
Post #58166 9th Feb 2011 9:38pm
kljw
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Auto Santorini Black
hi
if any one has done this on a puma, and have a few pictures, it would be good to see them.
also, if you have a genuine land rover switch to turn on and off, what part number?
and my 3rd question, could these be put onto a timer like a heated window? if so, what should be used? Cheers
keith
puer claudius
Post #58513 11th Feb 2011 5:45pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
If you have a Heated Front Screen, why not use that to trigger a relay?, or even run them directly depending on the power requirements. Thumbs Up
Not wanting to drill holes just yet, as my 90 is only 10mths old, I just used elasticated plastic bags over the mirrors when parked up this winter. Worked fine even when -12C Whistle
Post #58515 11th Feb 2011 5:58pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
As Keith, concerning the 3rd question, I would suggest to use the switch and timer unit as used for the heated front screen.
I've installed these parts last week (on my Td5), wiring is pretty straightforward Wink.
Depending if you plan to use a timer module you could consider to install YUG000470LNF (Heated Rear Screen Switch)
or YUG000460LNF (Heated Front Screen Switch).
See also :
http://www.reedx.net/landrover/mods/2002dash/part5/index.htm Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #58517 11th Feb 2011 6:03pm
kljw
Peter
chhers for the info, never though about just using the heated screen setup, but that will be my first point of attack, then may be a second relay if and when permits. Cheers
keith
puer claudius
Post #58534 11th Feb 2011 6:35pm
jst
i have a HFS and my thoughts were to split the output from the HFS relay and take a feed from there to each mirror as well as the screen.
any know if there would be an issue/problem doing that? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #58655 12th Feb 2011 4:40pm
James...
My mirrors run off of the front screen circuit, but where the timer unit triggers the screen relay, i just ran another cable to a second relay, which runs both mirrors.
both relays sit next to each other in the under-seat compartment/box thing. the mirrors have their own fused supply.
Post #58732 12th Feb 2011 9:28pm
jst
cheers Jamie,
so the HFS goes off on time but the mirrors dont?
i was thinking of taking the feed from the timer relay and splitting it to a 2nd relay (if needed?) for the mirrors?
so the mirrors go on with the button but off with the timer same as the screen. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #58779 13th Feb 2011 11:15am
