Page 963 of 1385 <123 ... 962963964 ... 138313841385>
CarMan wrote:
Fantastic in beautiful sunshine though foggy locally. Never done it before, but will post some pics hopefully soon and hope to go back to do it the other way. Apparently more rocky than it used to be, water was quite low in places, though still came in the footwells and made interesting by the ice.
It's a fab lane, it was 2008 when I last did it Shocked I've been threatening to go back ever since. Where does time go?
I miss this beaut too
Post #583387 8th Dec 2016 12:59am
Defender830
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Galway Green
From this...
Post #583539 8th Dec 2016 7:55pm
Defender830
To this......
Foam £7.50
Leather £10
Labour, sweat, general fustration priceless.
End result pleasing.
"Oh is that what i am leaning on" quote from the wife.
Post #583541 8th Dec 2016 7:58pm
It's surprising what you can do yourself to good results isn't it.
I did th whole of my cubby, and built it.
On a different note, haven't done anything with my 90 today bar use it but thinking of things I will be doing with it.
Delighted to see my trailer wiring manufacturer has now started selling LED lighting parts that are plug and play.
Glad I didn't jump the gun before the LED types were released or I'd have already modified some wiring probably,
Not cheap though again.... but plug and play is worth it. Mr. Green TheThunderRollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #583596 8th Dec 2016 11:37pm
Huttopia
On Friday I took the 90 for its MoT on Friday and it went straight through, happy days. Also booked the Heritage for its first service and contacted the supplying dealer to say 'it doesn't appear to have been Supagarded, but I have the invoice for it'.....
Post #584218 11th Dec 2016 9:00pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Cured the annoying squeak from the clutch pedal 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #584681 13th Dec 2016 9:10am
Huttopia
Rosco - how did you cure the squeak? I've got that feature in the pick up.
Post #584683 13th Dec 2016 9:15am
Post #584704 13th Dec 2016 11:21am
Rosco
@ Huttopia, can of 3in1 oil and a torch. Spent probably 15 minutes last night, with my head in the footwell spraying a little on every spring, hinge and moving part I could find, whilst fighting with the door.
Was still squeaking when I went indoors, leaving the can in the cupholder with a plan of further investigation today in the day light, but it wasnt squeaking on the way into work this morning. Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
Post #584753 13th Dec 2016 2:42pm
Procta
topped up the clutch and gave the key barrel a clean with spray.
Post #584807 13th Dec 2016 5:43pm
Rosco
Rolling Eyes Spoke to soon. Squeak has returned 2007 - Stornoway Grey 90 XS SW - Gone
Post #584843 13th Dec 2016 7:26pm
Huttopia
Mouse with a sense of timing.....
Post #584862 13th Dec 2016 8:30pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Squeaky clutch pedal? This worked for me:- http://www.defender2.net/forum/post263911.html Dave
Green Goddess - 1998 Defender 110 300tdi
Post #584882 13th Dec 2016 9:27pm
Rosco
Dave, thanks I'll see if I can pick one up ready for fitting over the break 2007 - Stornoway Grey 90 XS SW - Gone
Post #584884 13th Dec 2016 9:40pm
JWL
Opened the spanner boxes this morning to sort out my front diff. it had stopped me dead in the middle of one of the busiest roads in Hereford City Centre in the afternoon rush hour(or three) a month ago. Limped it up on the pavement, jacked up the front, both front wheels span independantly but the prop flange was solid. Off with the prop, difflock in and wait for the rainy day fund to build up to be able to buy a full secondhand axle. That way the thinking is that I can strip my knackered diff out and replace the parts needed with good parts out of the bought in axle. Yes mine has ABS but the only difference is the CV joint, mine has a pick up ring for the sensor which is through a different top swivel pin. If the CV has gone then it's just as well to buy new ones anyway.
All would have been fine if the damned courier company had played ball and hadn't taken a week to get round to delivering it! So, it got here yesterday late afternoon and today I jacked mine up, got the blocks out and started after getting the boys to school and college. Five hours, plenty of time, pull the hubs out, halfshafts still intact, all good. Moved across to the donor axle, did the same then pulled the diff out. Got underneath and went to pull the knackered diff out and, Censored . the diff has collapsed and it won't come out. It will come so far, enough to feel the centre pin loose in the bottom, a couple of planetaries floating about all stopping the damned thing from coming out. I've tried undoing the prop flange, pulled the seal out, knocked out the bearings in the vain hope they'd go through the cage but not a chance.
I've got no choice now but to drop the axle off and try different angles and see if gravity may help, if that doesn't work then at least I have the other axle tube to get a working axle back on the motor.
So hopefully tomorrow afternoon we'll be out and about again, good job really as the MoT is booked in for Thursday morning. I know the axle wouldn't be part of the test but I just want it done instead of driving round in diff lock all the time.
Post #584912 13th Dec 2016 11:10pm
