Home > Puma (Tdci) > Developing transmission rumble and vibration
Page 8 of 8 <12345678
Strang3rr
Russia 2008 Defender 90 Puma 2.4 HT Santorini Black
Cetane try without a snorkel, i think it is not difficult....
Post #584375 12th Dec 2016 9:58am
Okan
Switzerland 2009 Defender 110 Puma 2.4 SW Stornoway Grey
The lower frequemcy vibration i had was the one where it felt like the engine was shaking out of its mounts.
Infact it felt like a mount had failed. This fault only occurred under sustained load at an rpm below 2000. I think 1750 was the worst. Towing really showed the fault.
For me that's exactly the point. So I will try to change my gearobox and engine support as soon as possible. I allready did so many things. Cash and time begins to miss a bit.
Okan its definately worth doing the intake mod. If only to help it breathe.[/quote]
Yes I was looking at this thread:
http://www.defender2.net/forum/topic25864.html
It's a bit hard to make a good sealing part between snorkel and airbox as I saw on this page. Is it possible first only remove the restriction part in the airbox and the little plastic fan?
Best regards
Post #584376 12th Dec 2016 10:01am
Cetane
United Kingdom 2010 Defender 110 Puma 2.4 HT Galway Green
Every little helps.
Here are 2 photos I sent a friend for a laugh. They tell a story. The pound coin is being held up to a joint in the original system. Its the bit that connects directly to the air intake.
Post #584397 12th Dec 2016 12:18pm
Strang3rr
Cetane OK you think, that if i will disconnect the pipe from airbox and take a drive - vibrations will go away? Smile
Post #584400 12th Dec 2016 12:26pm
Okan
Thanks for pictures Cetane. It's impressive!Very Happy
For Strang3rr best thing is to try, but in my case It didn't change anything. The too hi torque of my map was the only cause of vibrations.
regards
Post #584418 12th Dec 2016 1:27pm
