Home > Puma (Tdci) > Blown my turbo :(
fredbloke
Wales 2010 Defender 110 Puma 2.4 XS DCPU Firenze Red
Blown my turbo :(
So my 60 plate puma has blown its turbo. Fairly annoying as its only on 40k miles. Wheres best to try and find a new one. Or is a hybrid worth it?
Post #578912 19th Nov 2016 10:29am
Froglaise
Hybrid rebuild for better flow = more engine power at more or less the same boost.
No particular recommendation but worth a call to Turbo Technics ?
Post #579197 20th Nov 2016 3:48pm
Fos_landy
United Kingdom 2009 Defender 90 Puma 2.4 HT Keswick Green
get them to have a look at the wiring - the 3 fault codes on the diag' will only show the turbo as having an issue - if you happen to use a 'less knowledgable' garage, they will tell you to replace.
have them check the wiring going into the turbo - pin plug with the spooled wires round it. Mine went, but it was a wire here that had snapped...
check that first!!
sorry if you're already aware of this, but i wasn't and it's good knowledge to have in the armoury - especially for someone as mechanically 'special' as myself!! Laughing Defender 90 Puma 2.4
Post #581879 1st Dec 2016 10:00am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
^ what he said^
We have had a few with allegedly blown turbos,
9 times out of 10 it's an actuator/ wiring loom fault. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #581884 1st Dec 2016 10:18am
smb
Good reason to upgrade to one of the Variable Turbos like from IRB, BAS, ALIVE, ETC...
Post #581890 1st Dec 2016 10:54am
JOW240725
Might be worth a call to Pete Bell at Bell Auto Services might have a take off turbo when someone upgrades to VVT. James
Instagram @suffolk_rovers
Post #581894 1st Dec 2016 10:56am
fredbloke
I will ask about wiring e.t.c.
It makes some horrible noises though and loads of smoke!
Luckaly i have a warranty on it so im hoping they will pay out!
Post #582679 4th Dec 2016 5:47pm
My bet will be actuator, hopefully cheaper for you anyway. Fingers crossed. $W33T $0U7H3RN $UG4R
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #582695 4th Dec 2016 6:46pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
I won't tell my whole story of blown turbo's and which problems I ran into Big Cry but I found it impossible to get just the actuator. They told me it isn't "released" by Land Rover. So if anyone has an adress where to buy a separate actuator please inform me. I hope I never need it but I fear for the worst Laughing a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #582826 5th Dec 2016 10:21am
You will find new actuators listed on Ebay, I think. At least, there were some sources there when I thought mine had failed.
Engine harness failure is mroe common than actuator failure, so it is always worth checking the harness very carefully before jumping to any conclusions.
Post #582827 5th Dec 2016 10:47am
Tdi4
Beware!! the ones on eBay are just (cheap) knock offs. The original ones (as far as I know, see my previous post) are not for sale in Europa. I decided not to gamble but that's for everyone to decide for themselves. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #582828 5th Dec 2016 10:53am
Interesting. Thumbs Up
Post #582833 5th Dec 2016 11:43am
2hooky
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Firenze Red
my 110 DCPU (2013 model) went into limp home mode on Friday and had to be towed to Stratstone (wales) as its over 120 miles to home. After 4 days they have said its the wiring loom (£360 !!!) plus 2 hours fitting at £170 per hour which was a shock as the mobile line was really poor - but possibly even more !!!!
Trapped- so they will have to do it. It did seem like the turbo had packed up so in a way a bit easier to swallow. Obviously its 10k miles out of warranty.
Post #584777 13th Dec 2016 3:48pm
Harness damage is very common but is easy to repair if you are moderately competent with electrical repairs. That cost is shocking!
Post #584782 13th Dec 2016 3:58pm
jst
£170per hour! bloody hell Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #584798 13th Dec 2016 4:25pm
