Home > Puma (Tdci) > Blown my turbo :(
Page 2 of 2 <12
Is there a common failure on the wiring harness & any premptive steps that can be taken?
Post #584844 13th Dec 2016 7:33pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Just check the loom from actuator and follow it around the engine.
Unclip the loom, so you can check the underside for rubbing.
The loom on these engines are installed incredibly tight in places.
If you slacken them off, you can wrap some rubber tape or similar to prevent it rubbing.
The worse point is the fat part of the loom that runs across the front at the top of the engine. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #584845 13th Dec 2016 7:46pm
Fos_landy
United Kingdom 2009 Defender 90 Puma 2.4 HT Keswick Green
this was the issue with mine - once all the masking tape had been unwound...
always get the garage to have a look. lesson learned! Defender 90 Puma 2.4
Post #585193 14th Dec 2016 11:50pm
Page 2 of 2 <12
