Home > My Defender > Defender 90 LS/6L80 conversion. step by step!
Page 4 of 9 <123456789>
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Do you know which oil pump it has ? I may have been unlucky but I went through 2 "standard" oil pumps in the first year due to the bypass valve sticking in the bore and limiting the pressure. Fitted a "heavy duty" version which has a heavier spring on the bypass valve and not had a problem since. I did get very well practiced at stripping the front end though !
I only knew it had happened because I had an oil pressure monitor fitted. http://www.yorkshireoffroadclub.net/
Post #578604 18th Nov 2016 12:31am
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
Hey Dave,
Yes it has the high flow pump standard on this engine.
Pete 2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #578605 18th Nov 2016 12:34am
psimpson7
Made a fair bit more progress on this.
Engine is built, with the exception of fitting the loom. Filled with oil etc. A lot of the front end is refitted.
Oil cooler manifold for the Auto. Oil cooler sits in front of the Radiator.
For now I have the standard TD5 radiator in place. Will see how it copes. I have a 16" spal fan on order to help with the cooling.
All the water hoses are now sorted including the heater hoses which aren't in this image:
The bare LT230 has now been swapped out for a complete one which has been rebuilt with the heavyduty Ashcroft cross pin, and a sleeved intermediate shaft.
I haven't refitted the underdrive yet. That's still fitted to one of my other LT230's
Need to have a look at the power steering stuff lines next. Will hopefully have all the wiring fitted this week.
I have also stripped down a TD5 fuel pump assembly and have been looking at options to rebuild that with the Walbro pump I ended up ordering.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #581231 29th Nov 2016 12:02am
psimpson7
couple more pics:
Front prop UJ clearance!
I fitted the propshaft the other day, then I was annoyed it was filthy so removed it, cleaned it and refitted in with new nuts and bolts again!
2014 90 XS SW 2.2.
Post #581494 30th Nov 2016 12:34am
psimpson7
Have started on the wiring as well now. Had to unbolt the transfer and slide it back 10mm (on some longer bolts I fitted as guides) to allow me to get the connector into the 6l80e
The hard plastic lines are for the Evap/Purge valve (connector just behind the serp belt tensioner)
I need to redo these as they dont fit atall anymore.
2014 90 XS SW 2.2.
Post #581834 1st Dec 2016 6:22am
Wow, the prop is close! There's enough room for some axle articulation?
Post #581836 1st Dec 2016 6:33am
psimpson7
I think so. I can always drop down a size to the std UJ's. This front shaft has the larger 1330 joints as opposed to the earlier cars / rear shafts which are 1310's 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #581837 1st Dec 2016 6:47am
Stupid me! There's not much movement at that end anyway Embarassed
I shouldn't get excited and read about. LS swaps, the minute I wake up in the morning!
Post #581840 1st Dec 2016 6:51am
psimpson7
Laughing , one of my mates asked me the same question so its not that daft! 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #581841 1st Dec 2016 6:57am
davew
Mine's very similar, been competing and driving it for nearly 10 years now and it's never touched the gearbox/sump side.
I did have to carve a lump out of the gearbox cross member though due to the transfer box being about 6 inches further back on mine. I could have moved the cross member back but cutting it was a lot easier and I didn't want it too close to the centre of the wheelbase as it's taken enough grief where it is from grounding ! http://www.yorkshireoffroadclub.net/
Post #581878 1st Dec 2016 9:59am
psimpson7
Awesome, thanks Dave! good to know. 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #581892 1st Dec 2016 10:54am
JOW240725
Thumbs Up Bow down James
Instagram @suffolk_rovers
Post #581919 1st Dec 2016 12:44pm
L110CDL
Just love all your attention to the detail and your updates, many thanks Thumbs Up Bow down 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #582022 1st Dec 2016 9:15pm
psimpson7
Spent ages last night and this evening just doing fiddly and slow jobs.
Removed all the wiring for the rear winch for now. Wired up the starter and alternator, battery positive, and also the battery earths to the chassis and gearbox and from the engine to the chassis
I also refitted the starter motor and put the underdrive back on.
There is a fair gap between the loom and the manifold its just foreshortened by the picture. I picked up some wiring heat wrap earlier so will add some protection in a few places just in case.
Gear shift cable and underdrive cable will hopefully go back on tomorrow.
2014 90 XS SW 2.2.
Post #583032 6th Dec 2016 10:45am
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
Should you ever have issues with your ignition leads there are ceramic coated ones on the market from the US for around $120.-. (a full set!) I went through a Cpl of sets due to manifold heat. Depending auto cooler size and location I would add a check valve in the line too IMO. m
Post #583078 6th Dec 2016 1:47pm
