Home > Maintenance & Modifications > has anyone installed 4 point seatbelt? |
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 |
Hello,
recently saw the harry garage defender and i like the idea of the 4 point belts Is it easy to install on the bulkhead ? 2016 Defender 90 Adventure Edition |
21st Nov 2016 6:13pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
It depends how likely you are to need it I guess...
The lap strap ends are easy enough to mount using the existing mounting points. The rear straps on that one in the video look way too low though and, if mounting to the rear bulkhead you need to keep that in mind. If you mount the straps too low so they go downwards through the seat back you are actually relying 100% on the strength of he seat back in a crash. If the seat back fails not only will you be thrown forwards but your spine can be crushed in the process as your forward movement pushes your shoulders down inside the straps. In that respect a 4 point harness can be far more dangerous to the occupant than the standard 3 point. Ideally the rear straps should come out parallel to the floor and be mounted there. If you take a look at the MSA regulations for seat belt mounting they show the permitted angles for motor sport use. http://www.yorkshireoffroadclub.net/ |
21st Nov 2016 8:01pm |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 |
The standard 3 point is pretty easy to use and I still can't be arsed. The chances of me faffing with a 4 point is nil
But each to their own and if it makes you happy why not - just make sure you get the mounts right which in a Defender won't be easy. |
21st Nov 2016 9:01pm |
Ordered these TRS 3 point harness Clubman
The rear harness should install on the rear passenger seatbelt bolts. Click image to enlarge 2016 Defender 90 Adventure Edition |
24th Nov 2016 8:31am |
Click image to enlarge installed 2016 Defender 90 Adventure Edition |
29th Nov 2016 8:52pm |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 |
Dont forget the shoulder straps cant go downwards straight out the back of the seat unless you want back injuries in a crash.
To mount them properly, you'd almost render the rear seats useless with what's needed. Just my opinion of course and people do and get away with it, but do enough research and you'll see my point. Start with the MSA handbook for a good starting point as they dont tend to say stuff without reason . I bought some a while ago and also have a full cage, but still wont be fitting any more I dont think. Plus getting to the radio when strapped is impossible so you end up wearing without the shoulders anyway ... which is pointless! EDIT: Also ... try a drive-through when fully strapped up ... It's hilarious! |
30th Nov 2016 12:32pm |
As above, avoid a crushed spine.
30th Nov 2016 3:16pm |
