Home > Maintenance & Modifications > has anyone installed 4 point seatbelt?
SkyFallSilver
Kuwait
Hello,
recently saw the harry garage defender and i like the idea of the 4 point belts
Is it easy to install on the bulkhead ? 2016 Defender 90 Adventure Edition
Post #579496 21st Nov 2016 7:13pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
It depends how likely you are to need it I guess...
The lap strap ends are easy enough to mount using the existing mounting points. The rear straps on that one in the video look way too low though and, if mounting to the rear bulkhead you need to keep that in mind.
If you mount the straps too low so they go downwards through the seat back you are actually relying 100% on the strength of he seat back in a crash. If the seat back fails not only will you be thrown forwards but your spine can be crushed in the process as your forward movement pushes your shoulders down inside the straps. In that respect a 4 point harness can be far more dangerous to the occupant than the standard 3 point.
Ideally the rear straps should come out parallel to the floor and be mounted there. If you take a look at the MSA regulations for seat belt mounting they show the permitted angles for motor sport use. http://www.yorkshireoffroadclub.net/
Post #579516 21st Nov 2016 9:01pm
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
I may sound like the fun police but I would never use 4 point seat belts unless you have a roll cage....no space to duck away in case of a roll over. Just IMO. m
Post #579540 21st Nov 2016 9:50pm
Riccarton
Scotland 2012 Defender 90 Puma 2.2 HT Zambezi Silver
The standard 3 point is pretty easy to use and I still can't be arsed. The chances of me faffing with a 4 point is nil Very Happy
But each to their own and if it makes you happy why not Thumbs Up - just make sure you get the mounts right Shocked which in a Defender won't be easy.
Post #579542 21st Nov 2016 10:01pm
SkyFallSilver
Kuwait
Ordered these TRS 3 point harness Clubman
The rear harness should install on the rear passenger seatbelt bolts.
Post #580044 24th Nov 2016 9:31am
SkyFallSilver
Kuwait
installed 2016 Defender 90 Adventure Edition
Post #581427 29th Nov 2016 9:52pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Dont forget the shoulder straps cant go downwards straight out the back of the seat unless you want back injuries in a crash.
To mount them properly, you'd almost render the rear seats useless with what's needed.
Just my opinion of course and people do and get away with it, but do enough research and you'll see my point. Start with the MSA handbook for a good starting point as they dont tend to say stuff without reason Smile.
I bought some a while ago and also have a full cage, but still wont be fitting any more I dont think. Plus getting to the radio when strapped is impossible so you end up wearing without the shoulders anyway ... which is pointless!
EDIT: Also ... try a drive-through when fully strapped up ... It's hilarious!
Post #581593 30th Nov 2016 1:32pm
As above, avoid a crushed spine.
Post #581650 30th Nov 2016 4:16pm
