Home > Td5 > TD5 door shutting |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Only when cold in frosty weather with mine.
29th Nov 2016 2:54pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5110 |
It is all down to adjustment, using the correct shims and perseverance till you get it right.
My doors close with the minimum amount of force, no slamming whatsoever. It does take a little bit of tweaking to get them right, adjusting the two hinges and the position of the catch on the striker and if needed placing a shim behind the striker or sometimes removing a shim if fitted. Also making sure that the door rubbers are fitted perfectly, in fact if you tap the door rubbers gently all the way round with a soft mallet to make sure they are seated right this can also make a big improvement. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
29th Nov 2016 3:11pm |
chri$ Member Since: 27 Mar 2014 Location: Kent Posts: 16 |
Try following the link from Land Rover UK forum in this thread http://www.defender2.net/forum/topic50378.html
Mine shut even at -4 this morning |
29th Nov 2016 4:21pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Mine stayed shut at -6C. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
29th Nov 2016 6:30pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5849 |
I found changing the striker plate helped with getting the doors to shut
These ones > http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...Sw14xWF5Lu on mine I had no nylon roller. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
29th Nov 2016 9:50pm |
countyboy Member Since: 24 Oct 2015 Location: leicestershire Posts: 32 |
Grateful thanks to all who have replied to my query.
I certainly have something to work on now. Best Regards Robert |
30th Nov 2016 10:00am |
